Throttle cable removal
No special tool needed
Just run in the adjuster all the way in so you will have slack in the cable's. The push cable is the hardest, usually no adjustment other than on the drum under the tank..
I usually disconnect the cables at the drum first and then the handle bar perch. Makes it a lot easier. They are just aggravating to get off.
