Voltage Regulator
Old 05-08-2013, 10:46 PM
doc ock's Avatar
doc ock
doc ock is offline
Default Voltage Regulator
I think my regulator is going but. I check the voltage at the battery at idle it's 13.5, rev to 3k 14.2, ok that's good. I don't have a diode meter but set meter to DC and get 12.8 through the regulator and as I had the ignition on it dropped to 12.6. Does this indicate a bad voltage regulator? It is 12.6 with ignition off too. Or will the meter make a difference not having the right setting? 2004 FLHTI
Old 05-09-2013, 01:47 PM
doc ock's Avatar
doc ock
doc ock is offline
Went by the dealer today told him what was going on. After I said I'm getting 14.2v to the battery he said must be just a loose connection.
Sardo
05-07-2017 10:42 AM
Arjeje
General Topics/Tech Tips
02-18-2016 10:21 AM
jonmerrill
12-27-2015 04:19 PM
Tired_bird
04-22-2011 04:40 PM
TravelingBiker
10-12-2009 09:41 AM
Quick Reply: Voltage Regulator
