Starter just spins
Be sure you post back what you find out. The solenoid is under that small cover on the starter on the right side on the starter. Think it's only $15 repair kit from Harley. The two L shaped copper contacts and washer. I personally would start there even if I replaced gear clutch. (it's a sprang clutch, and I guess it could jam out if the grease got too hot.
All good gen. The starter clutch protects the electric start motor while the solenoid action throws the pinion gear into the ring gear, cranking the engine. If you take off the primary be extremely careful pulling on that starter pinion (don't!). What will happen is the starter will engage and that's with the ignition off!
