Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Not sure if this is the right forum but it seems to be an electrical problem I'm having so here's the problem. I have factory installed accessory port or cig. lighter on my 2011 street glide. I plugged in my phone charger and the lighter stopped working and so did the acc. button light. Checked acc. fuse, even replaced fuse but still will not work. Read on here that the wires were reversed sometimes from factory. Also changed wires around but still won't work. Any ideas what the problem might be? Does it have an in-line fuse that could be blown?
You might find another fuse on your bike labelled "Power Outlet" have a look I bet it is blown. Yes HD added a new fuse to the fuse box and your looking at the Accessory fuse which is the wrong one.
I have a 2010 Limited and the same thing happen to me!!! Except I was running my GPS. I pulled the Fuses and all were Good even the Power Outlet. The Power Outlet Works Fine but the cigarette lighter and accessory switch have no Power...
