07 Train, Bassani Pro streets, k&n and PCIII intalled +problem...
Old 02-25-2007, 09:43 PM
rino's Avatar
rino
rino is offline
Default 07 Train, Bassani Pro streets, k&n and PCIII intalled +problem...
First ride after install, pro-streets are LOUD and deep. Bike is running great (pre programmed by fuel moto).
5 minutes in I get the orange check engine light and the red battery light. Checked the error codes and they are PO132,PO152 (front and rear o2 sensors are rich), PO562(low battery voltage).
I capped off the o2 sensors as directed with eliminators from the pcIII ????
The battery is the real mystery, next day it was completey drained and the bike would not start. I put a charger on it and am waiting for it to finish, Last check the battery was at 12.7 volts and about 70%.
I'm more concerned about the battery problem than the o2 sensor problem since those are not a factor anymore (eliminated).
Any help,opinions,suggestions,thoughts,tips or hints are appreciated.
amunozroadking
07-11-2015 09:09 PM
burntorangefan
09-18-2014 03:55 PM
06UltraBig95
03-14-2014 08:54 AM
dirtdobber
01-26-2013 05:35 PM
ken05
08-17-2007 10:46 AM
Quick Reply: 07 Train, Bassani Pro streets, k&n and PCIII intalled +problem...
