Power Commander Map Source?
Old 07-31-2013, 01:16 PM
TJRKC's Avatar
TJRKC
TJRKC is offline
Default Power Commander Map Source?
I bought my bike used with a PC-V already installed. I would like to re-map it, but a map for my set up cannot be found on Dynojet's site. FuelMoto only provides customized maps if you can prove you purchased the tuner from them. Does anyone out there in Forum-Land know where I can get a map to download for my setup?
2009 FLHX
96 ci
Stock Cam
Stock ECM
SE Stage I AC
Rhinehart Slip Ons
Thanks!
Old 08-01-2013, 02:10 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
Call DynoJet. This is a very common build and they'll tell you which map you need to use for your setup. The website isn't very intuitve..
Also FM, if you call them will do the same thing for you.. I know they supposedly only provide maps for purchases made with them but they're great people and will more than likely help you out.
Old 08-01-2013, 02:25 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
+1 on both comments!!
Dynojet's site really isn't easy to maneuver around in to find what you need.
Jamie and Kevin are great guys.
Old 08-01-2013, 02:54 PM
TJRKC's Avatar
TJRKC
TJRKC is offline
Thanks guys. I did contact both DynoJet and FuelMoto and both were very quick to respond. FuelMoto asked that I request a customized map from the website even though I am not the original purchaser. DynoJet provided a couple of different maps that they slightly modified. The ones they have for the 09 FLHX aren't configured for Rineharts, they seem to have more Bubs, Samsons and Vance Hines on there. When I talked to the rep at DJ he said that the map he emailed had been modified to help with my decel pop and the intermittent missing. He also suggested a Firmware update so I'll be flashing it with that as well. He said there have been numerous changes to the software for the PC-V since 2009 and that may by itself make a difference. I know that not all popping on decel is necessarily a bad thing, but I do think the missing is so hopefully this will help.
Mugsy666
08-09-2016 11:37 PM
gargoyle13
06-18-2013 06:42 PM
supra0001
04-16-2013 05:39 PM
rietherll
05-14-2012 10:03 PM
mongomark
12-22-2009 10:53 PM
Quick Reply: Power Commander Map Source?
