Best Tuner - TTS, Power Commander, Screaming Eagle ...
Any opinion thoughts on what is the best tuner system for HD.
I have a 2008 Rocker and will be adding V&H Big Radial 2 into 2 pipes and a RS K&N air filter and have been told a tuner would be a good add on. Is it and if so, which one?
I am trying to research this and seem to identified HD Screaming Eagle, TTS Mastertune and Power Commander V? as viable options.
I installed the PC-V on my 07 FLHT along with SE Stage 1, Samson slip ones & a set of Woods TW-7H cams & she runs amazing - Nasty Bagger! My AFR is running at 1:13-9 & both cylinders are burning equally, no bluing on my pipes at all. I like it because it enabled me to remove the O2 sensors which helps my bike run cooler. PC-V is my choice by far!
I am in process of finishing my tune with the TTS. So far I love it. The TTS really allows you to go way farther than the power commander from what I compared. Plus the TTS doesn't stay on bike like the pcv. The screamin eagle pro race is somewhat similar to the TTS but I got that gut feeling that moco would somehow want the end user to take it there for something to get fine tuned. Most people I know just buy tuner and have dealer dyno it. I'm to diy and feel the TTS was the way to go. My bike is way quicker and smoother and not done fine tuning quite yet.
Haxxor
09-05-2012 10:38 AM
