TTS Mastertune Base Cal Map for 2006-2011 TC96" with SE204 Cams
Hi All,
I just wanted to start this new thread to directly assist those with their TTS tuning, who have a TC96 and SE 204 Cams.
I'm no tuner or pro, but it took me hours to find info with a start to tuning my bike with TTS Mastertune and this combination, so I thought i'd make it easier to find, so you can get tuning….
I went and had my bike dyno tuned by a TTS Master Gene Thomason from Gene Thomason Racing here in California, does a lot of tuning for Steve so this guy nows his stuff!
He got 100.1 Tq and 83.7 hp out of my bike. Check the torque curve!!!
All Stock, No Headwork, just pipes and A/C and the cams thats it. This thing goes like the wind. Not bad for $150 cams from craigslist.
If you have a similar set up and want the map PM me.
I will attach the dyno graph pic.
Those with 2007 Deuce 96"TC, Stock Heads, SE204's, Big Radius 2/2, Spike A/C, have a pretty close Base Cal Map for a Starting Point that runs good. (Keep in mind all engines are different).
Enjoy folks! Ride Safe!
Symo
Symo
Hi Symo
I have a 2010 FXST with Vance and Hines Straight Shots an SE 28721 oval shape Air cleaner and SE 204 cams and would like the map for this set up on the Mastertune TTS which I have. Currently running the TTS map for the 255 cams CAA176-04 Bike runs good but was wondering if the map you mentioned would be even better.
Thank you
John
Perth Western Australia
Thank you
John
sgreen1456
11-29-2006 04:30 PM
