Thundermax ECM Thread
#471
#473
#474
Need some help/expertise...just installed a new-to-me 309-460 unit on my 07 Electra Glide. Everything on the unit was cleared out and I started with a clean and accurate base map for my bike/setup. I set all of the AFR's for my liking as well as all of the basic settings and all loaded successfully. I initialized the module a couple times with the ignition as well as allowed it to come up to temperature idling without touching the throttle as per the installation instrucitons.
Took the bike out for a 50 mile ride and it did amazing, came home and re-wrote the module to load in the learned fuel offsets from the first autotune session and all looked great.
On the second ride, the bike shut off a couple times when idling after a few seconds of coming to a stop. Didn't matter if I came to a stop in neutral or first gear, it seemed to want to idle funny or make an adjustment in the idle speed and then it would shut off. It would start back up totally normal and then idle fine after that.
Thoughts??
Thoughts??
#475
Thoughts??
Thoughts??
#476
Reload the original map you started with. Do the throttle learn again. Don't bother with automapping until you have 500 to 1000 miles on it.. Whenever you start the bike make sure the throttle is closed. If you like to have your hand on the throttle when pressing the start button make sure that you are not rolling on the throttle slightly. It will screw stuff up..
#477
