Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Shut the bike off, went to start it. Nothing, no click, no lights, the only thing that happens is the speedo lights up and shows the mileage. Key Fob will put it in security mode with no problem, turn signals will flash indicating this. Battery is putting out 12.7 volts. Main relay is working, all fuses are good. I'm baffled. Any help on what to look for?
Found the problem. Pull off your dash on the gas tank. Your main wiring harness under the dash will be exposed. Push it together good and put a zip tie around it so it won't pull apart. My harness pulled apart very slightly but enough to cut power.
I will bet that the harness is loose. Fingers crossed. I learned from a Harley Mechanic that this is a problem with Harley's, although minor it is a problem they always look at first. Let me know how you make out..
