CANBUD HD Lan Help
CANBUD HD Lan Help
Ok so some jackass decided to vandalize my bike while it was put up for storage. They cut the wiring that comes out of the frame and goes threw the bars to the handlebar controls. How can I repair the canbus wiring? I have been told that I cannot solder canbus wiring. Is there a a replacement wiring harness I can buy or will I have to replace the entire switch housing? They are $225 per housing.
I am not an exact expert, but this is what I do know for fact.
1. HD service manual shows switch replacements being spliced and soldered in place. So as far as switches it is OK for sure. (At least on my 2011 SG)
TBW I am assuming. Several people, here when doing bars, have spliced the TBW and no issues.
So in my opinion, yes you could. I would make sure you have enough length so the splices are not binding when you go lock to lock.
Hope that helps some.
Good luck!
Good luck!
Whomever told you that canbus can not be spiced is confusing ethernet cat 5 with canbus. It can be spliced by soldering or good crimp connections the key is good low resistance connections and to maintain the twist in the cables as much as possible. There is no shield in canbus, Do NOT GROUND EITHER CANBUS LINE. CANBUS LOW IS NOT GROUND.
