Lost speedo then digital odo, bang bang stop.
Old 02-05-2014, 11:25 AM
dynaglyder's Avatar
dynaglyder
dynaglyder is offline
1st Gear
Default Lost speedo then digital odo, bang bang stop.
Anyone got any ideas? Was doing about 80, lost my speedo needle, few seconds later my odometer display, started misfiring and got worse until I lost power. Lights were still ok but starter is just clicking and not turning
'98 Dynaglide
Old 02-05-2014, 11:38 AM
hvacgaspiping's Avatar
hvacgaspiping
hvacgaspiping is offline
Received 16,244 Likes on 8,380 Posts
Loose battery cable? Blown fuse? Those are the most obvious things.
Old 02-05-2014, 12:11 PM
dynaglyder's Avatar
dynaglyder
1st Gear
Thanks bud. Checked leads but have never had to change a fuse in 10 years, do you know where they live on a dyna?
Old 02-05-2014, 12:16 PM
hvacgaspiping
No, and my last bike was an `09 Dyna SG. I never had any occasion to check a fuse. I would get a service manual, though.
Old 02-05-2014, 12:22 PM
dynaglyder's Avatar
dynaglyder
1st Gear
Just dusted off my Clymer. Cheers
Old 02-05-2014, 01:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,498 Likes on 4,612 Posts
Sounds like a dead battery.
Old 02-07-2014, 06:02 AM
dynaglyder's Avatar
dynaglyder
1st Gear
You may be right, or maybe charging system. Put it on charge and was able to turn over motor. What do you reckon, get battery and charging system tested?
Old 02-07-2014, 04:03 PM
nevil's Avatar
nevil
nevil is offline
Just start by getting the battery checked properly, it's more likely to be that than the charging system. Most auto parts stores can do that for you. Also check the battery cable at the ground to be sure it's clean and tight.
Old 02-07-2014, 05:01 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Have the battery load tested, then check the charging system.
jim70
Electrical/Lighting/Alarm
12-28-2016 04:13 AM
dynaglyder
02-05-2014 10:09 AM
mac777
03-15-2013 04:49 PM
bh76
08-20-2012 04:20 AM
flat4fan
07-11-2011 03:42 PM
Quick Reply: Lost speedo then digital odo, bang bang stop.
