Coughing through air filter
My 03 Roadking coughs at low speed and idle. I've changed engine temp sensor, throttle position sensor, air temp sensor, crank position sensor. I've cleaned the throttle body and map sensor.
Only does it after warmed up.
All stock with high flow air cleaner and slip on pipes. 40,000 mi.
Really got me puzzled.
Thanks, Alan
Thanks, Alan
Received 3,930 Likes
Possibly a leak somewhere, resulting in too lean a condition.
Kevin may be correct. Something to try and its easy. How about disconnecting the Fueler, put it back stock, and try it. Fuelers and add on tuner DO wear out, in fact. Crap corrodes, etc. Look at electrical connections for the Fueler, too.
If it runs OK without the Fueler, it's the Fueler. If it still does it, it's the bike.
Lets get THAT question out of the way, first.
I'm going to pull it off and try it. I would think the lean condition would give me an error code but not a single one. I'm not sure when the cough occurs in relation to the valve position. It happens at idle and low speeds (under 30). Cam chain tensioners just replaced recently.
I'm wondering now if it might be associated with bad pushrod adjustment.
That's another issue that will be corrected this week.
Thanks for all the help
