92 evo pops and dies after getting warm
I have a 1992 evo 80" and I am having problems with it popping and then shutting down after it gets hot. or if i stop somewhere after running it for a while it wont start back up right away like it is flooded. If I wait ten or fifteen minutes it will start right up. I have an s&s shorty carb, a screamin eagle electronic ignition and a dyna coil new harley plugs accel cables and a pingle high flow petcock. at first we thought it was vapor locking i put a new pre formed fuel line on it so the line would not kink going into carb, wrapped the line in a heat sleeve to protect against radiant heat and eliminated fuel filter the petcock is not getting clogged the vent is clear of blockage in tank i just replaced the coil with a new dyna coil. I also took apart the carb to check if float is sticking or if jets are clogged everything looked good, I am thinking the only thing left is the electronic ignition module. Any Help would be nice if anyone knows anything please let me know.
