Opinions Please
Opinions Please
I am about to buy a tuner fro my StreetGlide. A very well respected builder / mechanic in my area recommends the Screamin Eagle super tuner pro. When I asked why, he said that because I spend some time on the road he thinks its the best choice because any Harley shop and most indys are familiar with the unit. He acknowledged that there are many tuners out there but he thinks there are more mechanics familiar with this unit than others and the odds of finding help if needed are better.
Thoughts?
Thoughts?
The Digital Technician can do whatever it does with or without a SEPST. And... if a Digital Technician cannot fix it? They swap parts. STILL will not need a SEPST to have a Harley bike fixed at a dealer.
Now, THAT was the point in this, to let folks know they do not have to use a SEPST as a tuner. One can use a TTS, a Direct Link, or a PV tune, just as well. Dealer can still use their digital technician.... with some effort, for some.
If a dealer ever said they need to add some fuel at 2500 rpms and 50 MAP, I would fall over dead. It's not something that happens.
So, for you? And piece of mind? Sure... run a SEPST. Nothing wrong with it, about same as anything. And, I was NOT arguing against it, either. I was arguing a point that your mechanic mispoke, and for you to know the real deal. There can be a plus with the SEPST, in that YOU have piece of mind while riding. That stuff counts.
If you have a decent dyno shop you will be going to? The best bet is to ask them what it is that THEY like to use, not any of us!
I didn't think you were arguing against it. I like the way you think and understand your point. I am looking to make some changes to my bike without giving up any reliability. Sometimes that's hard to do with limited knowledge. I don't need to buy the Harley tuner. I was only considering it based on what I was told. There are many tuners out there, and most are less expensive, which leaves me with another question. Is the Harley tuner more expensive because its Harley? What does this tuner do that others don't?
I'm not an expert -- have a Thundermax in my highly modified '04 Heritage myself -- but I think the tuner you choose probably depends on how much you plan to do with your motor. If all you want to do is pipes & intake, something like a power commander, v&h fuelpak, or the SE product you've been recommended will probably do just fine. I agree with the notion that if you go with something that's prevalent at the HD dealerships, your opportunity for tech support is probably a lot greater.
If you think later on you may decide to do more upgrades to the bike such as cams, stroke/bore kits, heads, etc., then you probably need to consider closed loop applications that can be programmed for the upgrades to properly manage the air/fuel mixture. THat's why I went with T-max on my Heritage. On my '11 FLHTK, I don't plan to do anything more than pipes & intake, so I'm looking at the V&H fuelpak for that one.
n0useforaname
23
09-11-2017 07:57 PM
