Rates for a Dyno Tune
Around here in Ohio and also in St Louie... between $350-500. That price does NOT include the costs of a tuning device like a TTS, PV, or SEPST.
In St Loius? I would recommend C&S Speed shop in Alortin, IL for any tuning needs. Jason was trained by Doc and is now-a-days an excellent tuner.
Dealers and some shops may charge by the hour. Thats not good, IMHO. It takes me between 6-9 hours for a good tune and my rate is $400... that covers any and all it takes to do a complete tune without worrying about a clock on either side. Getting a 2 hour tune is NOT getting a tune.
But... a two hour tune speaks for itself. VEs, It takes over an hour to get the VEs, on a dyno, pretty damn close from 2k rpm to 4500rpm, right? So, what is left? Do you think they really fiddle with WOT fuel? Some will, and that will entail a 2-3 hour tune.
Now... you guys have used or at least looked at whatever tuner you have... are there more tables than simply VEs? Of course there are. All the various timing tables, crank to run tables, IAC tables, AE, DE, EGR, etc. It appears to me that maybe 70 or so % will work rather well with most of those tables as is. But... how does one really know without messing with the tables in question? This is especially true of timing and AE.
It was the Wiz, right here on HDF that make me aware of how AE can effect things and now I incorporate this in all tunes. I have, myself, taken over two hours playing around with AE and Throttle progressivity to make a bike stop stumbling coming off of a red light. How about WOT timing? That will take multiple pulls, and then one will have to repeat the fuel lines, because the VEs will get altered by the timing changes.
How about UNDER 2k rpms? Getting low VEs take some time and effort, but pays such a huge dividend at the end it is amazing, to me anyways. Gathering good data from 800 rpm to 2000 rpms takes quite a bit longer than normally getting the 2k and up RPMs.
Cold starting... there is NO real formula with that, that is all trial and error. How much fuel when cold, how many crank steps to the IAC when cold. Have to play with that a bit... and when it says cold.... it has to be cold. Room temp. How long does one have to run the fans to bring it back down, temp wise?
There IS some work with things if one wants a decent tune. It is THE reason a lot of shops want a bike for more than a days time.
NO ONE gets rich at flat rate tuning. Well, almost no one, anyways. I sure do not. Not someone that gives a crap. Dealers, etc... that is not giving a crap, it is a service that allows a dealer to sell a build, first and foremost.
Just think about it.....
No it does not. That is why I always recommend getting as much info before hand as possible.
dyno tune
had mine done at harley dealer in Sacramento area, $384.00….took approx 4 hours, don't know how long ACTUAL dyno time …have TTS ….got USB copy of tune, no timing adjust, to me it look like the basic map and VE's set to afr… returned with ping and they only dropped timing 3/4 degree across map, made no diff in ping, I finally figured that out my self …
tripleb1911
08-19-2016 02:45 PM
