08 Nightster fuel tank removal
Old 05-28-2014, 05:59 AM
fissco1234's Avatar
fissco1234
fissco1234 is offline
Default 08 Nightster fuel tank removal
I need to remove my fuel tank to replace the gaskets on my forward rocker box. I plan on running it low on fuel before I do this. My question is, do I need to remove all the fuel from the tank, or is there a spring check valve at the quick disconnect where the fuel line connects to the tank? I expect a little fuel to drain out of the fuel line, I just need to know how big of a container to catch it in.
Old 05-28-2014, 09:18 AM
parrishbjj's Avatar
parrishbjj
parrishbjj is offline
Dont need to drain. Just disconnect and you are good. Like you said, a little will leak on disconnect but that is it.
Old 05-28-2014, 11:09 AM
fissco1234's Avatar
fissco1234
Thanks man
Streebo
General Topics/Tech Tips
07-08-2016 09:50 AM
ramu3527
05-22-2015 07:27 AM
mlrailguy
02-06-2015 01:30 PM
jiffylb1
Exhaust System Topics
03-31-2010 02:37 PM
Johneb48
10-19-2005 09:40 AM
Quick Reply: 08 Nightster fuel tank removal
