super tuner
Old 06-14-2014, 10:51 PM
shovelheadbill's Avatar
shovelheadbill
shovelheadbill is offline
3rd Gear
Question super tuner
what is the difference between the super tuner and the race tuner i looked up the software it seems to be the same i was told that they dont make the race tuner no more
Old 06-15-2014, 12:59 AM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
Race tuner is for pre 08 Bikes. Super tuner is for 08 and up bikes. Totally different programs and made by different companies.
Race tuner needs a dyno as there is no DIY option. Super Tuner can be done DIY if desired. If you desire the Super Tuner, you will want Screaming Eagle Super Pro Tuner.
Old 06-15-2014, 09:03 PM
gmeikle's Avatar
gmeikle
gmeikle is offline
A wee bit of history via Australia
The original SERT ( Screamin' Eagle Race Tuner ) was available from HD dealers from 2001 to 2008 ( approx) You can still find "brand new" ones on ebay occasionally from HD dealer clearance auctions. easy to use, but as Wurk Truk says, only good up until 2008 Model year. This was a "black box" with orange /yellow script Bikes loaded with canned"MAPS" or more correctly calibrations ran quite well.Came with install CD and usually the computer cables as well.
This system was made for HD by a subcontractor/supplier , known as TTS. After 2009 models , this company continued to make their own product marketed as "TTS Mastertune". Widely regarded by NON Harley shops as the best option for tuning your Harley. Look on the Kuryakyn website for real good info on it. Boxes ( dongles) were black ,but recently are blue !
Harley themselves continued to supply thru the dealer chain the SEPST ( SE Super tuner). Firstly a black box , and now orange I do believe. Made for them by the Kent Moore specialist tool company who make deaker tools for many franchised dealers including GM.( I know , I used to work for GM for 15 years , 1981 to 1995) .
Now here in Australia at least , the HD dealers try real hard to get you onto this product , as it keeps you close/tied to them they hope. And once you've spent the money you'll most likely stick with your first purchase.
I have TTS on my 2008 CVO Springer 110" and I have an SEPST on my 2013 CVO Breakout , which I bought as a 10 month old used bike with the SEPST already done.
If I was buying from new for my Breakout I would have gone TTS for sure as i find it personally easier to use than the SEPST software/hardware.
Over the last 5 years I have put numerous Aussie friends and associates onto TTS, and I'm not a shop or a reseller , just a private dude who got into EFI bikes a wee bit because I felt I had to !
To "confuse" things , all 3 of these options are referred to as " a race tuner " , so when guys call me or speak to me I have to ask further questions as to which " race tuner" they have. Most Australian bikes now have the dealer installed SEPST supertuner as the dealers work real hard to upsell to every bike to attempt to " lock out" the independent shops.
Sounds awfully " up yourself" as they say here in Australia , but I have become kind of " the expert " amongst my extended crew. Even "consulting" to one of the indy shops haha...
Old 06-16-2014, 02:15 PM
wurk_truk's Avatar
wurk_truk
Exact same situation going on in the States, Mate. Canada is even worse!
SPX, now owned by Bosch is who makes the SEPST.
Old 07-17-2014, 07:52 AM
Architect's Avatar
Architect
Architect is offline
Received 4,895 Likes on 2,551 Posts
So I have a 2005 Road Glide, with a 95" motor and Screamin' Eagle Race Tuner installed by Dealership when the bike was new in '05. Over the winter I did the upgraded cam plate and a set of SE203 cams.
Made an appointment with my local tuner yesterday, you stated he may not be able to tune the bike with the "old" 9-pin tuner, and we may need to upgrade.
Is he messing with me or is this a legitimate problem?
Advice appreciated.
Old 07-17-2014, 07:53 AM
Architect's Avatar
Architect
Advice appreciated.
GittinThere
15
07-06-2023 03:29 PM
RomeoTango
The Dyno Room
16
02-20-2018 05:10 PM
TOMMYBLAZIN
18
09-08-2017 10:58 AM
Blue-Ice
Screamin Eagle CVO Models
08-23-2011 07:39 AM
biohopper
04-19-2008 11:14 PM
Quick Reply: super tuner
