Tune for 103", se 204, true duals power vision
Old 06-15-2014, 08:02 AM
Blt93932@aol.com's Avatar
Blt93932@aol.com
Blt93932@aol.com is offline
Default Tune for 103", se 204, true duals power vision
Anyone have a tune that's close to a 103" with se204 cams and true duals? I have cfr knockoffs, need to figure out a baffle setup, just recently put the tri glide pulley in, just want to try to dial it in more. Thanks!
Old 06-15-2014, 09:19 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
best bet would be get a start map from dynojet website and do your own auto tunes vs taking someone else's configured map and trying to modify it to suit your needs. this would be a good starting map for you. 12T103002402
or take a look at the S&S website. compare the specs for your cam to an S&S cam that's close and grab that map
Old 06-15-2014, 12:03 PM
Teardrop's Avatar
Teardrop
Teardrop is offline
I have one pm me your email address and I will send it to you.
Sent from my SCH-I535 using IB AutoGroup
Old 07-25-2014, 01:33 AM
PublicNuisance507's Avatar
PublicNuisance507
PublicNuisance507 is offline
3rd Gear
I have the same setup my fuel table is good but my spark maps needs help because my local tuner doesn't seem to work on that very well! I could use some help as well please
Old 10-25-2014, 12:20 PM
Brian Grenier's Avatar
Brian Grenier
Brian Grenier is offline
Stage I
I'm a new member here, even though I have been reading the forums for a couple of years and getting so much knowledge. Since being new I don't have the ability to PM yet and am interested in a good starting point for my 2014 fls that I'm putting the se 204 cams in. I have a fuel pak 3 and it can adjust all parts of my fuel map. Is there a way someone can help me with a good base map? Really looking forward to waking up my 103!
boston rg
03-11-2013 10:06 AM
brian newsom
Exhaust System Topics
05-06-2011 03:45 PM
allaco
10-13-2009 07:50 PM
loc
04-16-2009 06:44 AM
HDRider2002
04-11-2009 06:08 PM
Quick Reply: Tune for 103", se 204, true duals power vision
