Accel Stealth coil anyone using it yet
Our bikes use what we call ION Sensing Coils. These are manufactured by Delphi. Inside is a sensor that reads how much voltage it takes to make a spark.
When the voltage to make a spark varies, this signals different things to the ECM of the bike. Ping most particularly. If ping (spark knock) is detected in the combustion chamber... it is being detected by the plugs taking a different voltage to complete the spark. During a pinging condition, the combustion process is being disturbed inside of the chamber itself.
When ping IS detected, the bike will automatically pull a bit of timing in an effort to try to stop the pinging. If ping is detected long term (like a bad tank of gas) the ION Sensing will pull and keep pulled the timing for like 4 key ons.
All of this is to help protect the engine. IN the older days of cars, they bolted mini microphones to the engine block and an audible noise would trigger this protection. S&S tried that with bikes and it was a total failure. Nowadays GM and Harley use ION sensing instead as it it way more reliable.
It takes the stock coil, stock wires, and stock plugs to make this system work at its best.
And... I gave you an easy to understand version of what goes on. What really happens is right after the plug fires, there is like a fraction of a second glow to the plugs, this is the Ionization of the spark that was just produced. Ping can blow out that Ionization like we can a candle kind of thing, but you get the basics of this.
This is very cutting edge, let alone to find this stuff on our 1903 designed bikes! But... this goes hand and hand with the ECM on the bike is the most sophisticated ECM on ANY bike.... it is a 2 cyl. car ECM, in fact.
Instead of Harley investing in complete water cooling, they invested in the electronics to stay an air cooled bike.
IN fact, if you remove the plugs and try to find a spark? It will spark once and not spark again. The ECM on the bike can tell immediately, from that one spark, that there is NO compression. Pretty neat, huh?
Google Ion Sensing.
The Accell ones look to NOT have Ion Sensing, and I, myself would NOT be the one to give it a go. Go to a chevy dealer and look under the hood of any car there, yes they are single plug coils... but look how big those are... that bigness is to enclose ion sensing in each coil.
Google Ion Sensing.
