P0502 VSS High/Open Carb - would it make it backfire?
Old 07-22-2014, 12:40 AM
blakeusa's Avatar
blakeusa
blakeusa is offline
Default P0502 VSS High/Open Carb - would it make it backfire?
On my 2005 883C Sportster I am getting this code.
My speedo works and believe my turn signals, which is what I read is effected by the VSS - Vehicle Speed Sensor.
Bike idles fine - but does pop and backfire on throttle advance and start off sometimes.
Runs fine at speed, but will backfire out the carb randomly.
Just replaced all 3 carb intake gaskets and cleaned carb. No exhaust or intake leaks detected currently.
Would this sensor or a weak battery kick off this code?
I am going to reset and see if it comes back again.
Was thinking I had a bad CPS, not a bad VSS.
Ideas
pacman552sd
Carburetor Related
06-03-2015 10:39 PM
Robtarra39
06-19-2013 06:37 PM
joe byrd
Exhaust System Topics
12-13-2012 11:32 AM
ppilotmike
11-06-2011 07:25 AM
sunwise
06-13-2011 07:17 AM
Quick Reply: P0502 VSS High/Open Carb - would it make it backfire?
