TTS - AFR During De-Acceleration ??
Hi All,
I have noticed a number of fuel maps that have been created by TTS Master Tune, that during De-Acceleration the Desired AFR goes rich.
I have a 2013 883 Iron using such a map and chasing a problem, so I have created a number of Data Master runs to study.
I have noised that during de-acceleration AFR goes to around 13.5.
Now I thought the logic would be to cut the fuel or have a very high AFR. This is reflected in a number of Automotive papers I have read on the subject.
Why do TTS go the opposite way??
Fritzables.
Fritzables.
G'Day Pine Tree,
Thanks for the reply....
OK.... the issue is, when on a run and up to highway speeds (110 KPH) then come to a stop, the Engine RPM remains at around 2,000 RPM until the bike comes to a complete stop, followed by about 10 seconds before RPM returns to a normal idle speed.
The IAC Valve checks out all OK and I don't believe I use too many Steps associated with the IAC.
I am now think that because I am rich on the Deaccel plus IAC Steps that this is enough to cause the issue.
Mind you this will not happen in all cases though.
Fritzables.
Fritzables.
G'Day Pine Tree,
Fritzables.
Fritzables.
1. In an internal combustion engine. Decell pop can be caused by too much or too little fuel in the exhaust header. So it can be cured by adding or removing fuel at the zero throttle position or relative MAP location. On motorcycles it is favored to add fuel as this reduces abrupt throttle changes when transitioning from on the throttle to off then back on again. On an air cooled engine it also helps to cool things down.
2. A hanging idle as you describe is usually caused by a lean condition. Check for intake and exhaust seal leaks. Verify correct IAC steps, Then reset AFV.
Good Read Gents,
Thanks for the detail.
Better come clean, I am a Mechanic by trade and have built a number of high performance engines - but, they have all had Carbies and Distributors. This is my first go at Fuel Injection and Electronic Control Units, so fully aware about the pops and all that. :-)
I have the tune just the way I like, the thing pulls like a train so I am happy with Fuel and Ignition. I use a 98 Octane fuel so took the initiative of whacking in 5 Degrees of Advance all over - no pinging detected.
I have the Map to a point where I can start and the engine goes straight to Idle with none of the flare.
The only thing remaining is the issue of High RPM coming to a stop.
The only thing I am unsure of is the Warm Up Steps.
I have already cleaned the IAC Port but no change - I did this with the IAC in place - maybe I need to remove it instead??
The Oil Level is always kept to the full mark - maybe I need to review my logic on that?
The bike is newish and bought it last December with only 11,000K on the dial.
Thought about taking it to the Stealer as a Warranty issue but thought is a custom map.....
Fritzables.
Fritzables.
oldlefty
05-18-2015 11:17 PM
splattttttt
Fuel Moto / Jackpot Mufflers
02-16-2015 06:55 PM
