Screamin eagle 50 -54 throttle body on 107
Old 07-26-2014, 02:15 PM
brad75raiders's Avatar
brad75raiders
brad75raiders is offline
Default Screamin eagle 50 -54 throttle body on 107
I am in the process of putting together 107 from rev perf stage 2 heads tman 590 cams I have my stock 46mm and a stockscreamin eagle 50mm I plan on sending either unit out to be hogged out and polished. If i run the SE 50-54 all the literature says "you will need to flash your ecm" I am running a power commander 3 now on my 2008 Dyna lowrider. Any help will be GREATLY appreciated. Thank you in advance,
Brad
Old 07-26-2014, 02:16 PM
brad75raiders
or is the 46-50mm better???
Old 07-26-2014, 03:43 PM
mirrmu's Avatar
mirrmu
mirrmu is offline
Hi,
Contact powercommander to get a map for your specs, they will have something close and then can fine tune from there
The 54mm tb works fine, got 4 mates who have them on bikes as part of the stage 4 SE Race kit and they been faultless
Thanks
Mirrmu
Old 07-26-2014, 03:48 PM
mirrmu's Avatar
mirrmu
mirrmu is offline
Hi,
Do you use your afr map? MAP 20-60 and rpm 750-1250 may need some small change
Thanks
Mirrmu
Old 07-26-2014, 05:28 PM
brad75raiders
Thank you.
Old 07-31-2014, 07:22 PM
brad75raiders
Will my stock flanges bolt up with the acreami eagle t body? I see aftermarket ones but it looks like 2006-2007
I have a 2008 dyna
Frédéric CM
03-04-2018 03:38 AM
misfitJason
05-11-2013 10:51 PM
Mordrapheus
07-03-2007 08:11 AM
WIZARD
02-24-2007 09:59 PM
Quick Reply: Screamin eagle 50 -54 throttle body on 107
