starting problem
starting problem
Hi all, I have checked all the posts but not found anything to address my issue. I have a 2007 Ultra Classic. Was heading out for a ride yesterday and it would not start at all, it would crank alright but not even a hint of going. I ran the diagnostics and no codes.
I pulled the plugs and no spark on both. Got lots of gas, fuel pump runs, ignition fuse is good.
I had a FOB issue a couple of weeks ago but then it wouldn't even crank.
I have been using the kill switch to shutdown cause I just came over from a Honda with the sidestand kill, could this be the problem even tho it cranks.
Thanks, Rick
Thanks, Rick
Master Dee
02-20-2019 01:11 PM
