Fatboy runs fine for a while then dies.
Gonna check the CPS next chance I get. Also starting to wonder if the circuit breaker may have gone bad on me. I've read several comments about recalls on those. I'm inclined to think it's not that since my headlamp still works when the bike dies. I'm gonna check the wiring while I'm at it and see if I can't find a short somewhere. It seems to me like the engine is dying after it warms up for a few minutes and won't start again until it cools off.
Ran the bike again with the air cleaner off and the gas cap open. After it died, there is still fuel... If I twist the throttle, I can see it squirting in. So I suspect the spark, which sucks because I just change the ignition coil. Not sure the best way to check for spark after it dies, mainly because inn I'm sure about pulling the spark plugs while the engine is still hot.
Any ideas?
Any ideas?
GLIDEGASM
04-08-2014 03:46 PM
