Fatboy runs fine for a while then dies.
I have a 2002 Fatboy. Recently, on my way home from work, the bike just died with no warning, almost like I just turned of the key. Battery cables are fine, lights still work, etc. Try to start, no luck. After about ten minutes, I try again and she fires up like a champ. Go for about 6 or 7 miles, then same thing again and won't start again until it cools down for a while.
Only other thing is I had just topped of the tank with gas, but this is the same station I've been filling up at for four years now.
I checked all the wiring I can without taking the bike apart. Put in neutral in the shop and fire up. Runs for about ten minutes then dies. If I try to restart, it turns but doesn't catch... sometimes a small belch of flame comes out the tail pipe.
Any ideas?
Any ideas?
Iron lHorse (03-30-2020)
Mines EFI so I doubt your problem is same. The cracked vent tube wouldn't allow the fuel pump to build up pressure in the tank so my bike would cut out and pop thru the intake. Good luck finding the trouble. It's probably something simple.
