Fuelpak3: Auto Tune and decreased fuel economy
I have a 2014 FLHXS..bought it a few weeks ago. This is my first bike from scratch if you will...my previous bike, a carbed softail was bought used and needed nothing so I am now learning about mods, tunes, etc.
During a trip back east, I installed a DK Outlaw 587 AC; VH Twin Slash slip on muffler; and VH Fuelpak3. Flashed the map and proceeded to auto tune during a side trip from PA to Cape Cod. After reading a bit more on the auto tune, perhaps I did not tune it properly as I had it active on the bike for several days running each time I rode and applying the learned values intermittently. After the 400 mile trip back to PA, I finalized the tune. On my ride back to Illinois yesterday, I noticed what I feel to be a drastic decrease in fuel economy...from about 42 mpg to 33 mpg. Still getting some decal popping...mostly when shifting from 3-2-1 gears. Definitely notice a decrease in heat, increase in power and throttle response...just really didn't think the fuel economy would suffer as much as it did. Any thoughts?
ok, tell us. do people not get these auto tune gadgets so they do not have to do manual tuning?
As was suggested above, the so-called "auto tune" feature is based completely on someone else's algorithms and not the rider's. Someone else determined what the rider is going to get not what the rider necessarily wants or needs.
To be happy with an "auto tune", one needs to be willing to accept the level of performance (start up, accel, cruise, decel - including popping, mpg's...the whole bit) that's been dictated by someone else.
Yes, I got the flash tuner because I am not interested at this point in figuring it all out myself and I was not inclined to spend the money on the dyno. Not saying it wouldn't be worth it...just wanted to give the fuelpak 3 a try as it appeared to fit my needs. As far as the auto tune goes...someone else's algorithms? I thought the point of the auto tune was that it computed measures while riding and then applied the values learned during the tune so it would be a custom tune of sorts? Anyway it's all beside the point...can anyone provide me with feedback regarding the decreased fuel economy? Thanks.
Yes, the "system" takes certain measurements and then gives them to the "auto tune" part to do its thing.
But the "auto tune" manufacturer is concerned because they have no clue as to the condition of any bike. So, they build in a LOT of safety margins by allowing the "auto tune" part to make only a limited amount of changes (fuel and timing among other things).
So legally, it did "auto tune" but to what extent? That's the algorithms (or parameters as another poster said) mentioned earlier.
Remember...a competent turner with a full-featured program can do wonders with a bike (or make it run like crap). With an "auto tune" system, the tuner is pretty restricted and the rider will end up with what the manufacturer wants them to have.
I know it sucks to here some of this after one spends a bunch of money and not end up with what they THOUGHT they should have. The claims made by most manufacturers are usually legal but most are usually misleading...at best.
Good luck!
To the original poster. The Fuelpak FP3's AutoTune feature is calibrating the VE Tables (Volumetric Efficiency) of the bike and nothing else. When you selected a basemap to AutoTune off of which did you select?
The AutoTune will help hone-in the map for bikes with slightly different setups than what is offered from our database. The maps that we create in house are created on a dyno. We tune the VE's, ignition, accel enrichment, decel enleanment, rev limit and AFR tables and more. It is highly recommended that you first start with the basemap that we recommend without running the AutoTune right away. The Adaptive Fuel Values of the bike will still make fine adjustments as ride and go through different conditions. If at that point there are still deficiencies within the map, then AutoTune off the V&H map.
