PCIII USB settings for Arlen Ness Inverted A/C and Rinehart True Duals
I have an '08 Street Glide that I recently purchased a Arlen Ness Inverted Air Cleaner for and I currently am running Rinehart 3.5" true duals. I have a Power Commander III USB but they do not have a map for it on their site. Any suggestions? Is the inverted series close to Arlen Ness' Big Sucker AC because there is a map for that.
Any help is appreciated!
In my conversations with Power Commander techs over a period of several years it has been pointed out that their product does not read logos or brand names. Pick a setup as close as you can. Chances are it will be close enough to not even warrant tweaking. In your case if the pipes match then pretty much any upgraded intake will make very little difference. But then again I am not in marketing. Put that map in and ride it some.
Hugh Jass
07-10-2008 08:09 PM
