Terrible dyno results
Hey all,
Just finished breaking in my net setup (listed below) and I took it to the tuner. He worked on it for somewhere about 2 hours and than I got the bike back.
Dyno chart displayed a whopping..... 80hp / 84tq...
That's terrible ... Everything is fitted right, all the numbers and the math adds up .. what could be wrong to explain this horrible outcome?
It seems to me based on the description, on paper the numbers should be around 95 TQ and HP for your high comp 95" TC. How does it run? Can you feel the difference after the build? Assume you did not have the High Comp Pistons before so can you feel the bigger bore and added compression in the bike, does it feel like you have more low end grunt? Also the higher compression will change the exhaust with power pulses being more pronounced. Assuming it runs better than before the build it could be the dyno....
All Dyno's generate Torque numbers then use software to calculate Horse Power. Torque is what the dyno measured and the torque load sensor in the Dyno needs calibrated from time to time. What I am trying to say is you can take your bike with the same tune and build to 3 different Dyno's and get 3 different results. And most likely the dyno farthest away from the last calibration date will have a radically different result compared to the others.
Hey all,
If your dyno run was done on a Dynojet dyno, and was done in the correct gear (either 4th or 5th depending upon the shop's practices), then yes, you appear to have a problem. But if it was say a Mustang dyno or other brand, maybe not.
that will not happen with the 37 only .510 lift and not knowing what size valves were used and how good they flow are key factors. for example my first setup was 107cid woods 555 set @ 10.3:1 with hillside stage II heads and 51mm hpi went off at 105/108 tuned.
