Help! I need some gas for my 04 night train
Old 09-04-2014, 12:47 AM
Rivithead8's Avatar
Rivithead8
Rivithead8 is offline
1st Gear
Default Help! I need some gas for my 04 night train
The fuel is not coming from the tank to the injector system. I swapped out the fuel filter and im still not getting fuel to the injectors.
Old 09-04-2014, 11:20 AM
jpowell490's Avatar
jpowell490
jpowell490 is offline
Do you have a clog in your fuel line below the tank?
Old 09-04-2014, 12:03 PM
Rivithead8's Avatar
Rivithead8
1st Gear
I don't think so. How would I check for that?
Old 09-04-2014, 12:06 PM
jpowell490's Avatar
jpowell490
Well a couple of things.
Is your valve defective where you turn the fuel off and on?
Have you had the tank off?
Have you looked in the tank and through the rubber fuel line to see if anything is in it?
Lastly, how did you come around to this issue. Bike just stop running or were you doing something to it?
Old 09-04-2014, 12:07 PM
jpowell490's Avatar
jpowell490
Oh, and you are saying injectors? An 04 Night Train had a carb. What gives?
Old 09-05-2014, 12:34 PM
Rivithead8's Avatar
Rivithead8
1st Gear
Default This is a injected 04 night train
I got this bike because a friend was going to loose it to impound. It had been dumped so I had it painted. It ran when I took the tank off. When I got it back together the fuel pump didn't work. So I replaced it it's working fine. But it's still not getting fuel to the injectors.?.....
Old 09-06-2014, 12:57 AM
jpowell490's Avatar
jpowell490
Your bike doesn't have injector's my friend, that's what I am trying to tell you.
Old 09-06-2014, 04:16 AM
Rivithead8's Avatar
Rivithead8
1st Gear
We'll mine does, and it would seem that they made a lot of them. Any way I am getting fuel at the check valve and the line Is clear to the intake any ideas?
Old 09-06-2014, 04:52 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,532 Likes on 3,784 Posts
You have the 2004 FXSTBI (last letter I is for injection) I have both the service and electrical diagnostic manuals and may be able to help. So when you key on, you hear fuel pump run 3 seconds powered by timer in the system relay?
Old 09-06-2014, 10:51 AM
jpowell490's Avatar
jpowell490
Gotcha, can you hear the fuel pump prime when you turn the switch on?
If you don't hear it, then check your fuses. If none are blown, then I would suspect a bad fuel pump.
If you do hear it and you have gas in the tank, then there is a blockage somewhere between the fuel tank and he injectors.
Quick Reply: Help! I need some gas for my 04 night train
