Stage-1 Then Install Cams [TTS]??
Old 09-14-2014, 03:01 AM
Fritzables's Avatar
Fritzables
Fritzables is offline
Default Stage-1 Then Install Cams [TTS]??
OK, trick question.
I have my Dyna sorted out with regards to a good working Calibration to suit Stage-1 (Air Cleaner / Exhaust).
Now, If I now wanted to slip a set of Cams into the bike, is it just a matter of doing a few more V-Tune's or will I need to look at a completely no base calibration ??
Old 09-14-2014, 06:30 AM
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
Originally Posted by Fritzables
OK, trick question.
Run the cam analyzer before you install new cams and see what the settings are (IVO at least). Then after new cam install, run cam analyzer again to see how much of a change.
If the new cams show a little change, you'll at least have to re-do the vtunes. Big changes may need a different map.
Old 09-15-2014, 04:58 AM
Fritzables's Avatar
Fritzables
Hey Pine-Tree, Thanks for the guidance, all makes sense.
toxic donkey
09-26-2012 05:56 AM
klaybus
Exhaust System Topics
01-08-2012 10:03 AM
Lawdawg
08-10-2011 03:06 PM
jsbridgew
05-17-2008 03:42 PM
kensim
07-14-2007 01:55 PM
Quick Reply: Stage-1 Then Install Cams [TTS]??
