Power Vision "Speedometer calibration" question.
Hi all.
I got a Power Vision unit and wanna load a proper map into my 2010 FXDWG.
In the PV software there is a "Speedometer calibration" parameter that depends on the tyre size.
The value in the canned map is 2150.
Since the Wide Glide (unlike the other Dynas) has a 21" tire, is this value (2150) correct?
Thank you.
Thank you.
I have no idea what the answer to your question is but I do know the speedometer does not work off the front wheel. I have an 06 Dyna and a friend has a 10 Ultra Classic and in both cases the speedometer gets its reading from a censor on 4th gear. So I would guess it's the rear tire your PV is referring to as that is part of the final drive formula.
UrbanRunner
05-13-2021 04:44 PM
