neck bearings/swing arm bearing
Received 4,614 Likes
Some 80 models had cleve blocks in the swingarm; if you have that, this article might be interesting for you, and has some photos:
http://www.bikernetbaggers.com/pages...e__Part_1.aspx
If you pull that swingarm bolt (sounds like you need to) be sure the transmission is supported so it won't fall. Probably need all rubber parts replaced, too. Just hope the bolt isn't rusted solid in there so you have to cut it and press it out of the swingarm and/or transmission. Check the manual for which direction to remove it, some are supposed to come out only on one side. Check the swing arm carefully for cracks when you get it off, you can get swing arm flex from that, too.
Thank you for sharing that info. It is interesting, and new me and to my 10+ years of IronHeads. I expect those are things that apply to some big twins, perhaps ShovelHeads.
You will not find cleve blocks in an IronHead Sportster. And the transmission is completely supported internal to the cases. It is not possible for it to be affected at all by removing the swingarm.
My bad, saw two gas caps in the photo and somehow my mind slipped into big twin mode; yep it's a sporty. I shoulda known better, have a sporty with two gas caps, too! Not real familiar with older sporties, mine are fairly recent acquisitions, but don't the Ironheads have roller bearings instead of spherical bearings like my later Evolutions? Should be much easier to replace than that mess in the big twins.
On the IronHeads replacing the swingarm bearings is probably the most overlooked maintenance item, next to the usual steering head bearings, fork oil and brake fluid like most old bikes. The most difficult part can be getting the pivot bolt out - on some [i got lucky on mine ] it is easy, on others you really do need a BFH
The author of the link i put in post #6 included very good, detailed photos of the parts.
i decided to put off the swingarm bearings for now
i am focusing on the neck bearing, front forks and front brakes for now
lots to do on this bike , plus i do enjoy riding it too
i bought a fork rebuild kit that is on order and some type e fluid, also plan on painting the front forks
hopefully tonight i will get the forks loose and post some picks of the bearings and neck cups
got some work done tonight on the bike, i got the forks out with a little help from a mallet and a block of wood and cleaned and rebuilt one side
on to the questions: the neck cups were so loose you can slide them and twist them by hand. the boottom almost fell out by itself. What to do about this?
the races had alot of scarring and need replaced. The upper bearing doesn't fit the shaft, it is very loose and unless im missing something i think it is the wrong bearing
the shaft is scarred where it has been rubbing the inside of the cups because the bearing top was so loose. it seems fine where the bearings contact it
also, the inner part of the bearing lower and the dust shield are still on the shaft. i cut them pretty deep and tried to break it with a chisel but could not get it
also the races are still in the cups. i left them there for now till i figure out what to do with the loose cups
iron mick, i need the same parts you ordered from v-twin manufacturing, i have the part numbers but i cant find anywhere to order them
i cant remember working this hard to order parts online before
JP cycles said they can order anything from v-twin but that i need to call in the order during business hours, that is the best i have so far
if any one knows a site i can order i would appreciate it
i need neck cups, races, bearings and dust shields for 80 xl
i dont care if they are from v-twin i am just having difficulties sourcing the parts
