Ironhead A place to talk about Ironheads.
73 sportster engine question
Old 03-02-2015, 02:16 PM
motorman1600's Avatar
motorman1600
motorman1600 is offline
3rd Gear
Default 73 sportster engine question
Hi, Just bought a 73 Sportster that has been in storage for 15 years. The issue I have is the rear intake valve was just kissing the piston and not letting me turn it over. Took the heads off and could see that it was hitting. Also pulled the side cover off to see if cams were timed correctly, but they fell out so could not tell. Motor now rotates nicely and cylinders are good.
So the question is, what are the reasons that come to mind as to why it was hitting. Valves are not stuck. rockers are good as well, Thanks in advance for your answers.
Old 03-02-2015, 10:04 PM
IronMick's Avatar
IronMick
IronMick is offline
My thought is that, as you suspected, the cams were not set right - especially since it now rotates nicely. I have no other thoughts on it for now.
Old 03-03-2015, 01:01 PM
motorman1600
3rd Gear
Default Cams out of sync
Thats what it was. PO set them wrong and when it did not work right he put it away for 15 years, then I bought it.
Old 03-05-2015, 11:52 AM
motorman1600
3rd Gear
Default piston in backwards
Hi, Besides the cam being out of sync, the rear piston was also installed with the notch facing the exhaust valve. I am slowly learning the details of the motor by trial and error.
Tommyz23
02-04-2014 08:52 AM
bentheresd
Exhaust System Topics
03-15-2013 10:45 PM
nickbauer48
Welcome Area Only
11
11-24-2010 02:52 PM
dc-ark
03-05-2009 12:41 PM
mcwheelface
General Topics/Tech Tips
01-04-2006 08:59 PM
Quick Reply: 73 sportster engine question
