Ironhead A place to talk about Ironheads.
shifter spline work in a 75 ironhead
Old 04-23-2015, 12:12 PM
Ironvet87's Avatar
Ironvet87
Ironvet87 is offline
6th Gear
Cool shifter spline work in a 75 ironhead
I bought my first harley yesterday. A 1975 harley ironhead sportster 1000, electric start. As Im cycling throught the gears the shifter spline broke clean off. what kinda labor time and work am I looking at doing. first harley, new to working on them or any motorcycle for that, and wondering If its something I should let an expert tackle or could I do by myself and save some money. any help is very much appreciated.
Old 04-23-2015, 02:06 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
72 Ironhead XLH is offline
Basically its not a hard job if you can understand the procedure.everything in the primary comes off, 4 trans door bolts.most of the tools you can make.
rear exaust, sprocket cover, sprocket and chain,grease seal. dead blow hammer on the sprocket shaft and the trans pops free.
Old 04-23-2015, 02:08 PM
Ironvet87's Avatar
Ironvet87
6th Gear
what is a dead blow hammer. just hit after all that? what is the labor for a project like this. what would you recommend? not oppose to doing it by myself. does all the trans components neeed to come out?
Old 04-23-2015, 02:09 PM
Ironvet87's Avatar
Ironvet87
6th Gear
thank you for your reply by the way
Old 04-23-2015, 03:09 PM
72 Ironhead XLH
A dead blow hammer is like its filled with lead shot vs a steel head hammer. Let me get a pic of the trans as it comes out intact. Do you have the manual?
Old 04-23-2015, 03:10 PM
Ironvet87's Avatar
Ironvet87
6th Gear
I know what you are talking about. The person I got it off of still has it. he is gonna send it to me
Old 04-23-2015, 03:19 PM
72 Ironhead XLH
Plus I have that part #9
Old 04-23-2015, 03:21 PM
72 Ironhead XLH
check you messages
Old 04-23-2015, 04:52 PM
IronMick's Avatar
IronMick
IronMick is offline
Before i respond in detail i would like to be exactly clear on which part broke. Please post a pic of your part and also refer to the diagram posted by 72 Ironhead XLH.
Old 04-23-2015, 05:18 PM
Ironvet87's Avatar
Ironvet87
6th Gear
PART 14. THE PART ATTACHED TO THE SHIFTER LEVER NEAR THE BOTTOM RIGHT OF THE DIAGRAM. THE PEICE WITH THE TEETH THAT GOES INTO THE BACK OF THE SHIFTER LEVER ITSELF. ty
Quick Reply: shifter spline work in a 75 ironhead
