Ironhead A place to talk about Ironheads.
idle issue
Old 08-05-2015, 12:20 PM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,194 Likes on 1,269 Posts
Default idle issue
75 XLH stock bendix carb. Non adjustable jetting. Electronic ignition.
having a little problem with my idle. I don't think this is the usual check the intake clamps thing either.
When the bike is hot and I pull the clutch in to make a stop, it will idle a little high, about 1,200 rpm, then drop down to 1,000 (normal) within 20 seconds or so. That seems fairly reasonable. However; after a couple of minutes at 1,000 rpm, the idle starts going down to 750 and the bike acts like it is going to die.
I hosed down the intake with a garden hose and the idle didn't change so I don't think there is an intake leak there. I also checked the float bowl level and I "think" I've got it right. The idle seems rich enough but I'm not sure.
any other ideas?
carl
Old 08-05-2015, 02:45 PM
IronMick's Avatar
IronMick
IronMick is offline
Well, it really does sound like an intake leak.
I do not think that the garden hose is a good test. You need a fine particle spray. The best is propane as the particles are extremely fine - a pure gas. WD-40 is the best second choice but, in either case you do have to spray a lot, and the WD-40 will leave some mess whereas the propane is very clean.
Just do not light it up, eh
Intake And Exhaust Leaks Tests
http://xlforum.net/vbportal/forums/s...ad.php?t=39766
Old 08-14-2015, 07:11 AM
Grog's Avatar
Grog
Grog is offline
Starter fluid / ether works good and doesn't leave a mess. I would also think about heat transfer
Old 08-14-2015, 05:38 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
like Mick said - its in the seal of the intake - just re do it all then try it with out changing any thing else - if you make 2 changes you will never know what did what
Old 11-02-2015, 12:23 PM
carlgrover's Avatar
carlgrover
I think I got this figured out. I took the carb off and the gasket inbetween the carb and the intake was partially blocking that little hole that leads up to the idle jets. I figure it didn't pull enough air through there to get the fuel into the intake at idle.
The gasket didn't fit very well. I'm pretty sure it's a Taiwan replacement. Anyway, I put a couple drops of glue down on it to hold it in the correct position, buttoned it all up and now it doesn't die down at idle anymore.
carl
John Harper
09-07-2016 05:38 PM
DDH
The Dyno Room
05-09-2016 06:54 PM
MUSHHEAD
06-13-2008 06:26 PM
jermil32
Ironhead
10-25-2007 01:47 PM
TMOORE
Exhaust System Topics
08-07-2007 10:40 AM
Quick Reply: idle issue
