coil secondary resistance only 12,000 ohms
Hi getting a bad misfire around 3,000-4,000 under load on 81 ironhead seems to be fine other then that bike wants to stutter and die coil primary is good but the secondary is reading 12,000 ohms looks to be getting weak spark coil is out of spec min is 16,000 can that cause that big of a problem?
sammyrockstar
12-24-2017 06:39 PM
