Ironhead A place to talk about Ironheads.
charging voltage problem
Old 11-19-2016, 09:22 PM
bhack544's Avatar
bhack544
bhack544 is offline
2nd Gear
Default charging voltage problem
So i bought an '83 xls and one of the problems im having is that it wont stay charged. It doesnt have the original generator style but whats called an "altenator conversion kit" at jp cycles site. When i checked the charging voltage it was about 11.2 at and idle and just about 12 when i would give it a good rev. I thought it was the charging so i went to jp cycles and bought the the same style system. And got the same results.... now my question is could it be just bad luck in getting bad parts or is it in the realm of possibilities that the previous owner bought some crappy aftermarket cams and my bike just isnt spinning it fast enough?
Old 11-21-2016, 08:30 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
72 Ironhead XLH is offline
you should get atleast 14v output from the system.There should be 2 wires leaving the alternator unit, measure the AC voltage there . Then reconnect the wires making sure the rectifier/regulator is properly grounded, measure at the output of the regulator/rectifier body
Old 11-26-2016, 03:05 PM
Hal64hd's Avatar
Hal64hd
Hal64hd is offline
Did you install the gear at the end of the shaft? And cams have absolutely nothing to do with your charging system.
Old 12-08-2016, 12:42 PM
Hal64hd's Avatar
Hal64hd
Hal64hd is offline
Any news?????
Old 12-08-2016, 12:49 PM
bhack544's Avatar
bhack544
bhack544 is offline
2nd Gear
Im gonna chalk it up to cheap parts even tho it wasnt so cheap. Gonna go back to old school gen type
aces&8s
EVO
24
12-06-2018 03:31 PM
HDPursuit
Electrical/Lighting/Alarm
08-22-2018 12:56 PM
riden2low
07-18-2008 07:44 PM
Roadglide3
04-07-2008 11:43 AM
superglideharleyguy
Shovelhead
03-12-2008 08:41 AM
Quick Reply: charging voltage problem
