can i reuse copper head gaskets?
ive done a few heads on autos and i would never think of reusing a headgasket.i have read different opinions by googling....mostly just general answers soneone was parroting out.---------it would seem like it would be fine to me but i wanted to ask here.thanks in advance.
The same reason you would never re-use head gaskets on a car should be applied to your bike.
You need to always clean the mating head and cylinder surfaces before re-assembling. The copper gakset will have formed to this crude creating a seal. When you put the old copper gasket back on those small scratches and dents will be left and create gaps for oil to leak from and create places of compression being lost.
Why take the chance of having to do the job twice.
If you anneal the gasket (heat it with a torch) correctly, you can reuse it. The annealing process takes the old surface impressions out of the copper and "plumps" it up so it will seal correctly again. I used to do this on old Triumphs, mostly out of necessity. If I could get a new gasket relatively easily, though, I think I'd just buy a new one.
That alone should convince you to get a new pair, along with rocker box gaskets, 12 cork push rod tube washers, 4 new oil line washers (for oil tubing alongside the push rod tubes) and I would get new intake O rings while I was at it.........pg
