starter wires? removing starter?
ok at first my 1976 sportster ironhead would just click when i tried to start it. i got a new battery, but now my motorcycle will try to turn over once or twice and just stop. it gives a quick rrrr, rrrr...rrr, rrr. (haha, thats the only way i can explain it) someone suggested checking my the wires on my starter. i did and i found one frayed wire... would that keep the engine from starting?
also... someone told me to take off my starter and check and make sure the starter motor isnt jammed. but how do i go about taking off my starter?
ANY HELP IS MUCH APPRICIATED!!!!!
The partial turning over of the starter (which then stops turning) sounds like a low battery charge. Attach a 4 ampere (or smaller) battery charger to your battery overnight. Check the level of battery water first! Charge the battery.
Then see if it will start.
If the starter turns the engine over, then the starter and battery are fine. If the engine does not start, then you need to look into the carb next perhaps.
In another post you asked about a black cylinder with 5 wires to it and that this cylinder was mounted under the battery. Post a pic of this and we can try to identify it. It may be a starter solenoid or relay switch............pg
Remove both spark plugs and see if it will spin through. While you are at it, check the spark plugs for firing. If you have spark and the engine spins, then all that is left is the carb.....as far as problems go. Let us know.......pg
However, if you have any loose connections or frayed wires in the starting circuit, then that could be causing the starter not to fully spin. You have said the wires were good and connections were tight.....Correct?
The next step would be to remove the starter motor then and check for binding, commutator, and worn out brushes.
I assume you do not have a factory service manual?
I can provide you with the instructions to remove and inspect/repair the starter motor, but first tell me which brand of starter you have, Prestolite or Hitachi?...........pg
edit note: You said in an earlier post regarding something about a black cylinder having bad wires? If what you are talking about is the starter relay then that is something you need to fix/replace before you remove the starter motor.
Last edited by piniongear; 10-03-2008 at 10:04 PM. Reason: added edit note regarding wires to relay.....
piniongear-- i dont know if it is the starter relay or not... it directly under the battery on the opposite side of the fuel tank. it has about 4 or 5 wires on it and i know of one that is bad for sure! one of these 5wires is connected to a small box right next to it. the little box has three coils inside.
