Front Brake caliper help!
The fork legs do not have a manufacturers name engraved or stamped on them anywhere. I do believe that Seepixlh and Piniongear are correct. I am going to try and find the 73 caliper. These are not cheap are they?
I am not sure if item #22 is on the bike or not. I'll have to check when I go home.
Thanks for yourknowledge I really appreciate it!
Item #22 is a spacer washer behind the disc, You may want to remove the disc to see if this #22 spacer is there.
Also, my comment regarding the indentation on the face of your disc was meant to suggest perhaps someone may have mounted the disc inside out? If you find item 22 on the wheel and if #22 fits inside the indentation on the disc currently facing outward, then the disc may well need the smooth face out and #22 sitting in the indentation.
Just something to check on. I really am of the opinion that your forks are 1973 Kayaba (mis-spelled I am sure) and what you are going to need is a caliper off a '73. You will know how expensive when you locate one. Be sure to try to get the master cylinder lever and brake line if it is available............pg
My next task will be to try and find new tires. The rear will not be difficult. The front tire is small. I am not near the bike currently to get the exact tire reading, but I believe it is a 16" diameter rim and the tire is about 2.25"wide. Does anyone know of a good place to find vintage small front tires, or have one for sale? I believe my rims are invader.
brake parts for 70's bike
I am restoring a 1966xlch. This bike is not 100% stock, and won't be stock when I get done with it. Although, most everything besides the seat, and forks will be stock. The extended forks up front are of unknown orgin. I really like the looks of them and would like to keep them on the bike. My problem is that I am having a hard time finding the front brake caliper. I recieved the bike as a basketcase and it was missing (along with a multitude of other parts). I have managed to find most of the other parts and it is coming along nice. Can anyone tell me what caliper I need for this? Please see the pics.
thanks,
Calabeast
thanks,
Calabeast
Old Dude Vintage Parts & Service[IMG]chrome://searchshield/content/unknown.gif[/IMG]
Toll free orderline 1-877-OLD-DUDE. 1-877-653-3833. olddude@mindspring. ... Old Dude Vintage Parts & Service is located at 4251 Wayside Court in Lilburn, GA
Received 1,211 Likes
Any reason you might not want a better caliper than that banana job? I'd bet FabKevin could hook you up.
http://www.fabkevin.com/banana%20cal...eplacement.htm
You'll have a brake that actually works as intended, and probably cost not much more than the assorted banana parts.
Last edited by pococj; 10-17-2008 at 06:52 PM. Reason: 'Cause I always wanted to be an editor!
