Black Smoke
Black Smoke
My 78 was puffing some white smoke. I went to the guy that built the motor and he told me it might be running rich so I leaned it out a little and white smoke went away now when I give it the throttle it puffs a little black smoke . It is a stock 78 with a bendix carb and short pipes with no baffles and a lollipop. It seems to run great no hesitatation when I go up thru thew gears. The plugs look good. Oh ya I do run 100 octane in it as well. So is everything as it should be or is the back smoke the sign of an issue?
Thanks
T-Ron
Thanks
T-Ron
I think the white smoke is probably moisture (steam) or blue smoke (oil) that looks white in small amounts. Black smoke is fuel (rich) and is probably related to the accelerator pump.
Ideally, you want the air/fuel ratio correct... I would be concerned over running it too lean and would rather be on the rich side, for safetys sake. If you aren't fouling plugs, it probably isn't a big issue.
Thanks
T-Ron
Thanks
T-Ron
yah, i ditched mine and did the cv conversion....its a totally different bike now.
I have a Bendix on mine...the old style that isn't adjustable. I have no complaints with it. At times it just makes the ride more interesting...found myself changing the Main on the side of the road on a mountain pass in BC a couple of times....but that just added to the stories I get to tell...
s
