Showa front end
Hard to say. I would go thru the J&P Cycles catalog and look at parts, and make a chart of year ranges for wheels, rotors, and calipers, and see if they match up.
OK, so you have a 69 XLCH, a 77-83 Showa front end, and a newer [but unknown] mag wheel. So we can ignore the year of the bike and the question is: Will the newer than 83 wheel mount in the 77-83 forks, and will the old rotor mount on the wheel, and will the brake calipers also fit?
Mick..please.
You could hardly ignore the frame year, as the triple tree stem has to fit the neck of the frame, and it is very different.
And when he says old rotor...... we know that 77-83 are dual disc, so what does old rotor (singular) even mean?
A rotor from a 76? Now they are completely different.
What year wheel? 77-83 is a 10 inch disc. Is the wheel for an 11?
WHO KNOWS!!!!!!!!!
The OP could also post the question on some of the other IronHead forums, such as ...
http://xlforum.net/vbportal/forums/forumdisplay.php?f=7
http://www.chopperweb.com/xl/XLlinks.htm
Sighhhhhhhhhh.....
Mick..please.
WHO KNOWS!!!!!!!!!
Mick..please.
WHO KNOWS!!!!!!!!!
Ironheads has single 11,5" disk from 73-77, dual 10" disks 77-83, 84-85 single disk same as evo ?????. cast aluminium wheel for sportster came in 77 (for xlcr, others 78) and it's made for two 10" disk. 4 different types of brake caliber
