Ironhead A place to talk about Ironheads.
1970 XLCH Speedo
Old 12-21-2010, 01:31 PM
C. Numb's Avatar
C. Numb
C. Numb is offline
Default 1970 XLCH Speedo
My speedo stopped working on me and I am having a hell of a time finding someone that can fix it. The 1970 XLCHs used Veglia speedos. Does anyone know someone that repairs them?
Old 12-21-2010, 03:04 PM
GA Ironhead's Avatar
GA Ironhead
GA Ironhead is offline
Some links I've collected from folks who had work done on their speedo. All have at least 1 positive recommendation and no negative that I know of. Some day I'll have mine restored.
http://www.nhspeedometer.com/
http://www.speedometersolutions.com/
http://members.shaw.ca/speedoshop/home.html
http://www.paspeedo.com/
More: http://www.google.com/#q=veglia+spee...ite=webhp&fp=1
Old 12-21-2010, 05:45 PM
C. Numb's Avatar
C. Numb
C. Numb is offline
Thanks! Some of these look promising. The "vintage Harley speedo" guys dont seem to know what to do with these Italian made Veglias, as they were only used on certain models over the course of a few years. I probably should have been looking for regular, general speedo guys all along. Thanks again.
Old 12-21-2010, 06:43 PM
IronMick's Avatar
IronMick
IronMick is online now
Did you check the cable and the drive unit for problems?
Old 12-21-2010, 07:20 PM
last12know's Avatar
last12know
last12know is offline
Old 08-05-2015, 09:48 PM
1970xlch's Avatar
1970xlch
1970xlch is offline
Stage II
Default no where to hook up speedometer cable
I got a 1970 xlch ironhead I bought a speedometer and cable there is no spot to hook it up what do I need and where does it go
Old 08-05-2015, 10:43 PM
Frigeratorman's Avatar
Frigeratorman
Frigeratorman is offline
Pre 1973 Iron Sportsters have the drive unit behind the sprocket cover, towards the bottom of the transmission area on the right side case.
Part number is 67127-52.
This is a known area of weakness in the cases and many have broken internally and grenaded a hole in the right side case. This would require splitting the cases and welding them up and milling back to proper specs.
This is what it looks like:
http://http://www.ebay.com/itm/67127...item4d36363890
Hope this helps......
outfishin35
EVO
13
07-06-2017 11:46 AM
golfblues
Dyna Parts
10-12-2013 09:04 PM
golfblues
Softail Parts
10-12-2013 09:02 PM
SuperFastGlide
11-08-2009 04:24 PM
Quick Reply: 1970 XLCH Speedo
