Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Classic > Ironhead
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Search
Ironhead A place to talk about Ironheads.
Welcome to HDForums.com!
Featured Articles:
When you think about the Nurburgring, Harley-Davidson is probably the last thing...
Read More
Summer time. You know what that means? The time for rallies is here. Where better...
Read More
Father's Day is June 16th, and if you're like most guys, you haven't even thought...
Read More
P
Thread Tools Search this Thread
Old 09-02-2011, 06:50 PM
Renderw Renderw is offline
Hang Around
Garage is empty, add now
Default Oil Diagram for a 74 sportster (ironhead)
I have the digram for the 78 to 81 but it's not the same.. pump has too many hoses..
does anyone have the older sportsters,
here is the one I have
Old 09-02-2011, 08:28 PM
IronMick's Avatar
IronMick IronMick is online now
This one shows the 1976 and earlier oil pump; newer pump has oil return from the front of the pump, not from the top of trans ...
Click the image to open in full size.
__________________
Mick
IronHead Forever!
Old 09-02-2011, 10:04 PM
piniongear's Avatar
piniongear piniongear is offline
1971 Harley Davidson XLCH
Here is what the factory service manual has showing the oil connections on the engine.
They mislabeled item #14 and #15 and I have corrected that with my note...........
I have never seen an oil diagram from the factory that would read like an electrical wiring diagram.
That is what the examples offered so far attempt to show, but one, they are for models later than 1974, and two, they are confusing (for me) to look at with all the hoses going everywhere. The oil pump was changed sometime in or after 1977, so a 1974 pump is a different animal.
pg
__________________
Rolling down the highway on two wheels since 1957...
Owner Red/White 1971 XLCH & 2003 FXDL-Silver over Black
Old 09-02-2011, 10:28 PM
Hang Around
Default do I connect the vent lines
I guess my basic question is.. would you connect the engin vent line to the oil tank (vent line)?
or do you let the two lines just vent to ground as I have now.. but I'm loosing alot of oil so I need to figure out how to fix that if they are not connected together..
Old 09-02-2011, 10:46 PM
piniongear's Avatar
Did you read my PM I sent you?
The vent on the engine needs a hose connected to it.
The other end of that hose gets connected to the oil tank vent nipple on the oil tank.
Under no means should either vent be allowed to drip onto the ground. They must be connected together using a hose.
pg
__________________
Old 09-02-2011, 10:54 PM
Hang Around
Default Thanks
I'll set this up tomorrow
Thanks again
Will
QUOTE=piniongear;8773555]Did you read my PM I sent you?
pg
[/quote]
P
Tags
74, 78, davison, diagram, engine, harley, hoses, ironhead, line, oil, return, schematic, sporster, sportser, sportster, wiring, xlch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Admin, Emails & Contact Details
