68' xlh starter engagement problem
Hi,
I have posted before but I own a 1968 sportster xlh. I had a starting problem before but it was because of a dead battery but here recently I have had problems with the starter gear staying engaged on the flywheel to crank the motor. Pretty much when I hit the starter button I hear the starter gear come out and engage the flywheel and it will crank the engine for about 1 to 2 seconds then I hear a loud grinding noise or it will disengage from the flywheel completely and keep spinning and once I let off the starter button it sounds like there is a rattling sound with the gear is still spinning, has anyone else had the problem with their bike or know a fix? Any help would be greatly appreciated. Also besides the new battery it has a brand new solenoid as well.
i have had so many people and dealers swear that 67-69 electric start sportys never existed..i had one with a block off plate at the starter,so it was kick only.. if it isnt from the volts dropping, check the clutch gear and the gear that pops out and drives it.. i have had both fail before. the teeth get sharp, and the one way clutch in the starter gear fails.
