Flames shoot out of tail pipes & has some piping
I have a 1981 iron head bird 30 over bike has some small problems has some flames comeing out the tail pipes @some poping going on. I drive the bike for43 miles did not have much problem had a couple of small pop but no flames came out the tail pip at that time. On my way back it started to pop more and flames where comeing out my tail pip from my rear jug. I have clean the carbrater put a new air filter on @replaces the plugs . Please help need to no what to check next. Thanks 1rickr
I am a first timeer to this site some one please help I have a 1981 iron head bird 30 over bike has some small problems has some flames comeing out the tail pipes @some poping going on. I drive the bike for43 miles did not have much problem had a couple of small pop but no flames came out the tail pip at that time. On my way back it started to pop more and flames where comeing out my tail pip from my rear jug. I have clean the carbrater put a new air filter on @replaces the plugs . Please help need to no what to check next. Thanks 1rickr
Quote
Quote
I would check these ...
1. pushrod adjustment
2. cylinder compression
3. ignition timing
4. intake and exhaust leaks
Here's a video ...
Here's some notes ...
Ironhead Push Rod Adjustment
Do this procedure with the engine stone cold. I usually do it first thing in the morning.
1. Remove the spark plugs. Remove A/C to make room to work.
2. Using a flat blade screwdriver pry the spring keeper off of each push rod; the bottom of the keeper pops out first, then the top. Alternately, use a 3/4" open end wrench to push down on the top of the spring retainer, then pry out the spring keeper with the screwdriver.
3. The lower push rod covers may be stuck tight against the bottom o-rings, but they can be loosened by pinching between thumb and finger [or carefully using a shop rag and a pliers] and twisting or rotating. Lift these up and secure each with a tall-S-shaped piece of 12 or 14 gauge household wire [not cable] [or a long piece of Plumbers solder such as 95/5 hooked over the rocker cover and under the push rod cover.
4. Jack up back end of the bike so that rear wheel is off the ground, shift to 2nd gear, rotate wheel until it clicks, repeat until you get to 4th gear. Now by rotating the rear wheel you are rotating the engine. Almost impossible with the plugs in; very difficult in lower gears.
5. To adjust a particular push rod, its valve must be fully closed [the valve spring is relaxed]. Valve position for a particular cylinder is determined by observing the corresponding push rod of the other cylinder. For example, when the rear cylinder intake valve tappet is raised [valve fully open, spring compressed], the front cylinder intake valve is fully closed, and the front intake push rod can be adjusted.
6. Check [and adjust if necessary] the push rods:
[a] use the rear wheel rotate the engine so that the rear cylinder exhaust push rod tappet is fully raised. The front cylinder push rod is adjusted correctly if it has no vertical or horizontal play, and you can just rotate the push rod between thumb and forefinger with no trace of binding or dragging.
[b] to adjust if needed: hold the adjusting screw in place with a wrench; with another wrench loosen the split locknut. Then turn the adjusting screw using fingers only until the pushrod's ball end is seated in the tappet with a "slight amount of play". Then tighten further as follows:
Option 1: Adjust on the tighter end of the range: There should be no vertical or horizontal play, and you should be just able to rotate the push rod between thumb and forefinger with no trace of binding or dragging.
Option 2: Adjust on the looser end of the range: Set the adjusting screw to finger tight so that you cannot turn the push rod between forefinger and thumb. Undo it a tiny bit so that it is just barely loose. Then loosen it 1 "side" for an exhaust or 1/2 "side" for an intake. "Side" refers to one side of the 6-sided adjusting nut.
EDIT: Experience here is that Option 2 is the better and most likely the correct choice.
[c] hold the adjusting screw in place with the one wrench; with the other wrench tighten the locknut.
[d] recheck the adjustment; it is common for the adjustment to go out as you do step [c], in which case [b] and [c] must be redone.
[e] repeat for the other push rods.
7. Use a flat blade screwdriver to push the upper push rod covers up, and seat them into the upper o-ring or cork washer.
8. Install the spring keepers, top end first, by prying them in under the bottom with a flat blade screwdriver.
3. ignition timing
Here's a video ...
Cylinder Compression And Leakage Tests
A compression test should be done as part of each tuneup. Record the results and follow any changes over time.
A cylinder leakage test should be done any time you are considering taking down the top end. This test gives you useful information regarding what you should look for when you have it apart.
Each of these requires a tester which you can buy at an auto parts store. A compression tester could be found for about $40.00 more or less, and a clyinder leakage tester for somewhat more than that amount. With the cylinder leakage tester you will also need a small air compressor. Should be able to find a small sausage style for under $100.00.
Use these tools once and they have paid for themselves, compared to paying $50.00 to $100.00 per hour at a shop. Buy a slightly larger air compressor [look for about 5 CFM @ 90 PSI] and you will be able to use it with air tools.
Compression Test
1. Ride the bike to get the engine to get it up to operating temperature
2. Disconnect and remove both spark plugs; insert them into the leads and place them on the cylinder heads for grounding
3. Screw the compression tester into the spark plug hole for either of the cylinders
4. Hold the throttle open, and ensure the choke plate is also open [choke **** pushed in]
5. Crank the engine through several rotations until there is no further increase in reading at the tester gauge
6. Record the final reading
7. Repeat for the other cylinder
The difference between the two readings should not be more than 10 psi. A low reading on one cylinder indicates possible valve or ring damage to that cylinder. To determine which, pour about 1/2 oz of oil into that cylinder through the spark plug hole and repeat the test. If the reading returns to normal then valves are good, rings may be defective. If compression does not return to normal then valves may require service.
Cylinder Leakage Test
This test will tell you what to look for at the top end tear down: worn exhaust valves, worn intake valves, leaky head gaskets, or worn rings.
This test is usually done immediately following a compression test. So the engine is at or close to normal operating temperature, and the spark plugs have been removed.
1. Remove the pushrods to ensure that the valves are closed.
2. Set the cylinder to be tested at or near top dead center [TDC] as this is the wear area for the rings ...
a] rear wheel off the ground, shift to 2nd gear, rotate wheel until it clicks, repeat until you get to 4th gear. Now by rotating the rear wheel you are rotating the engine. Almost impossible with the plugs in; very difficult in lower gears. For the following it helps to have either a shop assistant or a wide "wingspan".
b] you can see in thru the spark plug hole, especially with a flash light. You can also try inserting something soft like a pencil and watch it rise and fall as you rotate the engine with the back wheel; but be careful it does not break or get stuck! You will have to hang on to the pencil with left hand while rotating the rear wheel with the right.
3. Turn on the compressor, connect the gauge to the air pressure, and adjust the gauge
4. Thread the adapter into the spark plug hole and attach to the gauge
5. The gauge now shows the amount of leakage
6. Listen at each exhaust pipe. Excessive hissing here indicates the respective exhaust valve is not sealing
7. Listen at the A/C intake. Excessive hissing here indicates intake valve[s] not sealing
8. Listen at the timing plug hole. Excessive hissing here indicates the rings are not sealing
9. Listen around the cylinder/head connection. Excessive hissing here indicates the respective head gasket is not sealing
Notes
A mechanics stethoscope [with the probe removed for this test] makes a good listening device, as does a length of oil line hose.
Greater leakage results in a sound of lower pitch.
There will always be some leakage, especially past the rings.
Compression Test
Notes
Checking/Setting The Ignition Timing on Your IronHead
1. Checking vs Setting the Ignition Timing
You can check the timing without changing anything. Changing the timing can be done by one person but is easier with two. The ignition module or points is on the right side of the bike, the timing hole is on the left side. Easier with one person on each side than to go back and forth. Standard advance for the 1980 XL is 40`. I have mine set at about 35`. At 38` i get pinging.
2. Equipment That You Need
You need an induction timing light which you can buy at any auto supply store. Best to get the "dial back" type. These allow you to set a number [like 35`] into the timing light and then adjust the ignition module/points backplate until you are there.
If you have very well insulated spark plug wires the timing light may not sense the signal thru the wire. If this is the case then open the gap on the spark plug to 050 or more. Reset it to your normal gap [030 for points or 040 for electronic] when done with this procedure.
The induction clip is heat sensitive. The timing light will work better if the clip is wrapped in a shop towel to protect it from the engine heat.
It also helps to have a throttle lock as the timing should be checked/set with the engine at 2500 RPM.
You will need a piece of rubber oil line hose about 1 inch long. Press one end up against the side of a stone grinding wheel [or whatever] to make sure it is perfectly flat.
3. Front Cylinder: TDC Mark vs Advance Timing Mark
The TDC [Top Dead Center] mark is used with a dial back timing light to check the timing, or to set the timing at a specific degree, such as 37`. The advance timing mark is used to set the timing to the factory setting, such as 40`. Best is to use a dial back timing light to check or set timing.
4. To Identify Your Front Cylinder TDC Timing Mark
Remove spark plugs. Rear wheel off the ground, shift to 2nd gear, rotate wheel until it clicks, repeat until you get to top gear. Now by rotating the rear wheel you are rotating the engine. Almost impossible with the plugs in; very difficult in lower gears.
You want the front cyl to be at TDC. You can see in thru the spark plug hole, especially with a flash light; you can try inserting something soft like a pencil and watch it rise and fall as you rotate the engine with the back wheel but be careful it does not break or get stuck! You will have to hang on to the pencil with left hand while rotating the rear wheel with the right. Helps to have a good wingspan, or an extra person.
With the piston at precisely TDC look in thru the timing hole. You should see a drilled dot or a line. That is your front cylinder TDC mark. Once you know for certain what the TDC mark looks like you can check the timing.
5. Procedure, Checking The Timing
Begin with the engine at operating temperature. Remove the timing plug from the left side of the engine. Insert the 1" hose smooth end first, right tight up against the flywheel. I use a needle nose plier and twist it in there as firmly as i can. If it is not smooth and tight against the flywheel oil will spray out while you are working.
Start the engine, have it at about 2500 RPM [it will be extra noisy with the timing plug out], set the timing light at 40`, aim it into the timing hole thru the hose. Click it down one degree at a time while you look for the timing mark. If you don't find it you may have to work up from 40`.
If it is in the 35` to 40` range and there is no pinging then you may wish to leave it as is. With pinging on acceleration you may want to retard it by about 1/16 of an inch or less [see Math below].
6. Procedure, Setting the Timing
Remove the points cover from the right side. You will be rotating the back plate so first mark it so you can get back to the current position if needed. Make a scratch mark or use a permanent magic marker, or better still a small bright red or whatever color paint mark.
To change the timing loosen the two standoffs holding the points/ignition module and rotate the backplate. Clockwise advances [larger degree number] counter-clockwise retards [smaller degree number].
7. Some Math, How Much to Rotate
The backplate has a 3" diameter = 1.5" radius.
The circumference = 2 * pi * radius = 2 * 3.14 * 1.5 inches = 9.42 inches
The circumference = 9.42 * 16 ~= 151 sixteenths of an inch.
One rotation of the backplate corresponds to two rotations of the engine, so it is like a circle that has 2 * 360 = 720 degrees. 720 / 151 ~= 5
Therefore a rotation of the backplate by about 1/16 of an inch results in a timing change of almost 5 degrees!
Intake And Exhaust Leaks Tests
You cannot get a good tuneup if there are intake leaks or exhaust leaks.
1. Check for Intake Leaks
With the engine idling spray propane gas or WD-40 around the carb/intake/cylinder head joints. Propane is best because it leaves no mess, and is most easily sucked in thru leaks. WD-40 is said to work well because it has very fine spray droplets. Be careful to not allow any of either to get sucked in thru the A/C as this will invalidate the results.
Any change in engine RPM is a leak which must be fixed.
EDIT: Experience is that this procedure will identify larger intake leaks, but it may miss very small leaks that also must be fixed. And that propane is definetly the better choice.
EDIT: You have to do a lot of spraying to detect a small leak. Propane will be really clean. Anything else like WD-40, carb cleaner, etc will make a huge mess.
2. Check for Exhaust Leaks
Pour about 1/2 ounce of oil into each cylinder thru the spark plug holes. Run the engine at idle. You will get lots of smoke for about 5 minutes.
All smoke should come from the ends of the exhaust pipes/mufflers. Any other is a leak which must be fixed.
I am by far no expert and Husband doesn't do computers, but we had this problem on our Ironhead years ago. It seems the cam shaft was loose and moving around, throwing the timing off. It would ride O.K. for awhile, then start popping and flames from the exhaust as it heated up. They found it by removing the cam cover and watching it. You could see it wobbling around. This was just one of the problems we had, I also remember the voltage regulator going bad under the seat. I'm sure some of the more experienced on this forum can elaborate. In spite of all their issues, I still love Ironheads. Good Luck!!!
