Ironhead A place to talk about Ironheads.
1980 sportster's chain rubs on tire no matter what
Old 10-02-2012, 12:07 PM
ChooChooCharlie's Avatar
ChooChooCharlie
ChooChooCharlie is offline
Default 1980 sportster's chain rubs on tire no matter what
I ride a 1980 sportster and her chain rubs on the tire no matter what. I've tried re-aligning the tire multiple times and it looks like the tire might be to big. Also this bike has gone thru many hands and it looks like the hub might be backwards, is this possible??? i cant seem to find any worthwhile info out of the manual or parts catalog. also the generator light is always on and dims while i ride and now i have to push start it, she wont stay running with her lights on (starts popping really loud, loses power and dies) and she barely runs with em off (it died when i pulled in to my house) does anybody know whats wrong?
Old 10-02-2012, 12:20 PM
exemexer's Avatar
exemexer
exemexer is offline
Sorry man I don't know anything about 1980 sporties but you might get better responses if you post in the sportster section. Good luck.
Old 10-02-2012, 12:29 PM
ChooChooCharlie
fosho thanks
Old 10-02-2012, 12:46 PM
IronMick's Avatar
IronMick
IronMick is offline
BTW, this is the IronHead forum and you are in the correct place here. Most guys in a Sportster forum would not know about your 1980, your rear wheel or about a generator.
The stock tires for 1980 are 130/??-16 rear and 90/90-19 front. Often guys put a 140, or try even larger, on the rear and a 100 or a 110 on the front. In my experience these cause nothing but trouble. Many guys think that there is a performance or safety advantage in the larger tires but i disagree. And IMO the wide tire fad is over, or at least it should be.
There, that is the soapbox part of my answer.
Check the tire sizes. Install correct sizes.
A 1980 came stock with a disc rear brake. I do not think the wheel could be installed backwards. Post some detail pics of both sides of the wheel. Use PhotoBucket.
Gen light running dim while you ride is a classic symptom of sticking brushes. Easy to fix. Follow the factory service manual 99484-85 to partially dismantle the gen [do not remove any bearings], clean the insides with spray can electrical contacts cleaner, clean up the commutator, measure the brushes, put it back together, bench test it, and install it and give it a try.
More info here; note especially steps 6 thru 10 ...
IronHead Charging System Checkout
You need a multimeter. The digital ones are best and can be had for less than $10.00. A voltmeter is a multimeter set to measure DC volts. An ammeter is a multimeter set to read DC current in amps. The ohmmeter section of the multimeter will test for continuity. Continuity means that current may flow between the two points.
I find alligator clip probes are much more convenient than pointer probes. Occasionally a pointer probe is better so i have a set of each.
When using a Multimeter, if the object fails a test, repeat the test ensuring that you have good connections with the meter probes, especially to a good ground.
1. Fully charge battery.
It is not good enough to put it on a charger overnight and assume it is fully charged. Some batteries will take 24 hours to fully charge. The way to know for sure is to do a specific gravity test [for liquid filled batteries], or to use an automatic battery charger.
I have heard that you should never use a battery charger greater than 2 amps for any motorcycle; that it is best to use between .75 and 1.5 amps. Best are the automatic chargers such as Battery Minder or Battery Tender.
2A. Cell test battery [not for maintenance-free batteries].
Remove caps from battery cells. Keep the red voltmeter lead on a terminal and insert the black lead progressively into each cell, far enough that it contacts the plates. You should get readings of 2, 4, 6, 8, 10 and 12 volts. If one cell does not contribute its proper 2 volts then that cell is dead and the battery is no good.
2B. Load test battery.
It is said that, with electronic ignition, you should never crank the engine without grounded plugs attached to the wires. For this test you should install an extra set of plugs into the wires and set them onto the top cylinder head fins.
Disconnect both spark plugs. Attach voltmeter leads to the battery terminals. Crank the engine for 10 seconds [no more!]. Observe the meter WHILE cranking. If it goes below 10 volts then the battery is no good. Alternatively you can buy an expensive battery load tester.
Bring the battery up to full charge again before proceeding.
3A. Current Drain Test #1
Disconnect the battery -ve cable from the battery. Connect the ammeter between battery -ve post and the battery cable. It should read .003 amps or less.
3B. Current Drain Test #2
Disconnect the +ve terminal from the battery. Connect an automotive test light between the battery and the cable. If light comes on there is a current draw.
Note: To determine which circuit is faulty disconnect the circuit breakers or remove the fuses one at a time. When the light goes out you know which circuit is the problem.
3C. Battery Cables Test
With voltmeter connected to battery terminals check voltage while cranking. Then with voltmeter on battery cables check voltage while cranking. If voltage drop due to cranking [should not go below 10 volts] is different cables may be bad or there may be corrosion.
Here is another very simple non complex test you can do if you suspect that something is draining your battery when the key is off. This applies to bikes that have no digital instrumentation (like ironheads). Unhook your negative battery terminal. Touch the wire back to the negative battery terminal, there should be no spark when you do. If it arks and sparks (like a downed hydro pole in a rain storm in a horror movie) then something is drawing power when it shouldn't be.
4. Charging System Test
Measure the battery voltage with the bike not running. It should be at least 12.x; preferably it will be 13.x.
Measure the voltage with the bike idling at about 2000 to 3000 RPM. It should be at least 1.0 volts higher than the not-running reading, otherwise the charging system is not charging the battery. It should be at least 13.x, preferably 14.x.
5. Regulator Test
Disconnect the regulator. Connect your ohmmeter to the orange and tan wires. Note the reading. Reverse the connections. Note the reading. One reading should show continuity, the other should show no continuity. If the regulator does not pass this test it is no good. This is the circuit that prevents the reg from draining the batt when the bike sits overnight.
This test only tests one circuit in the regulator, so even if it passes this test it may still be no good. There are other tests of the regulator that require specialized equipment. These tests are in the factory and Clymer manuals. I recommend taking both the reg and the gen to an automotive electric repair shop for testing if needed. Note: these shops usually want to test both parts together.
6. Generator Test #1: Amperes Output
  1. Remove all wires from both A and F terminals
  2. run a jumper from F to a good ground on the motorcycle
  3. run a jumper from A to ammeter +ve
  4. run the engine at 2000 RPM
  5. momentarily jumper from battery +ve to ammeter -ve
  6. ammeter should read 10 amps or more
If the generator fails this test it must be disassembled for repair.
7. Generator Test #2: Residual Magnetism
Disconnect both the A and F terminal wires. Connect the +ve voltmeter lead to the A and the -ve lead to ground. Run the engine at about 2000 RPM. The meter should read at least 2.0 volts. If the voltage is low polarize the generator and repeat the test. If the generator fails this test it must be disassembled for repair.
8. Generator Test #3: Maximum Output
Remove both the A and F terminal wires. Connect the +ve voltmeter lead to the A and the -ve lead to ground. Run the engine at about 2000 RPM. MOMENTARILY [not longer than 10 seconds] connect a jumper lead from ground to F and read the meter. The meter should read 25 to 30 volts DC. If the generator fails this test it must be disassembled for repair.
9. Here's a good way to bench test your generator:
1. connect a jumper from the "+" battery post to the "A" armature terminal on the gen.
2. Connect a jumper from the "-" battery post to the "F" field terminal of the gen.
3. Now take a third jumper from the "-" battery post and touch it to the case of the gen.
If all is well the generator will run like an electric motor. With the gen gear pointing away from you the rotation is clockwise.
Don't try this with the generator on the bike.
10. Polarizing the Generator
With the generator fully installed in the bike, all connections made, ignition off; connect one end of a jumper wire to the gen A, and momentarily touch the other end to the battery +ve terminal.
Usually [but not always they say], you will get a spark at the battery terminal and a light clunk sound from the gen.
11. Polarizing the Generator - The Complete Story
1. with the gen on the bench
[i] jumper the gen A to batt +ve
[ii] momentarily jumper from gen F to batt -ve
Note: This can be done the other way around,
[i] jumper gen F to the -ve batt
[ii] momentarily jumper gen A to batt +ve
2. with the gen on the bike, wires not connected
[i] jumper from gen F to a good ground
[ii] momentarily jumper from gen A to batt +ve
Note: This technique is preferred over #3 because the good ground is better than relying on grounding the F thru the reg.
Note: As with #1 this can be done the other way around.
3. with the gen on the bike, all wires connected
[i] momentarily jumper gen A to batt +ve
Note: This is technically the same as techniques #1 and #2 as the F is grounded thru the reg.
4. For bikes with a mechanical reg [1959 to 1977]
Momentarily jumper between BAT and GEN on the reg.
Note: this is technically the same as all of the other techniques as BAT is connected to batt +ve and GEN is connected to gen A.
5. For bikes with a Cycle Electric Generator/Regulator
On the Cycle Electric DGV-5000 generators you have to remove the brush cover and touch a wire from the positive terminal of the battery to the positive brush lead of the generator to polarize it. You can't polarize the generator from the external terminals. (One of the terminals is the battery terminal, and the other has an internal diode.)
You have to try pretty hard to reverse the polarity on those generators and they rarely need to be polarized.
For clarification: Cycle Electric does have a voltage regulator (the CE-540) which looks very similar. It will bolt up to a standard Model 65A generator and has external leads which connect externally between the regulator and the generator.
The CE-500 bolts to a Cycle Electric DGV-5000 generator and the regulator is internally wired to the generator.
- With the CE-540 setup the generator can be polarized by running a lead from the battery + to the "A" terminal.
- With the CE-500 you need to polarize the generator at the positive brush lead.
12. Generator Brushes Assembly: Dismantle, Cleaning, Repair
1. The brushes holder and related parts can be dismantled without removing the gen from the bike. This is useful because, in my [limited] experience, if the gen light is coming on then one or both of the brushes is probably sticking. This can be easy to fix.
I am writing this from memory, not while doing it. I think i have the removal process right.
Remove gen end cap. Remove the bracket and brush cover strap. Remove the commutator end cover. There are 3 screws visible. Two just hold the brushes to the brush holder; these do not need to be removed. The third screw attaches a wire from inside the gen to the brush assembly. Remove this screw. Now the brush assembly can be removed.
Usually it is quite dirty in there so at this point i use a spray can of electrical contacts cleaner to clean up the mess.
The brushes will spring out of the brush holder. They must be each longer than 1/2 inch else replace both. Reinstall each temporarily and work them between thumb and finger to see if there is any binding.
To re-install brushes in holder use long twist ties from the kitchen. Pick out the twist ties after the holder is re-installed.
2. To remove the gen from the bike: Disconnect the wires from the A and F terminals; remove the two bolts from the gearcase side; raise the inner end toward the 11:00 o'clock position, lower the outer end toward the 5:00 o'clock position, and remove carefully.
For the rest you really need a manual. The FM is very good. It is usually not necessary to remove the gen drive gear - this requires a gear puller to remove. The rest of the gen dismantles quite easily.
Once opened up you can do more cleaning and inspection; again using the spray can electrical contacts cleaner.
The FM contains a number of tests that you can easily do once it is opened up: field coil test, shorted or open field test, grounded armature test, and open armature test.
The shorted armature test requires special equipment which a shop would have [a growler]. Doing actual repair may require special equipment such as a lathe, and perhaps experienced hands.
Old 10-02-2012, 01:43 PM
JohnnyC's Avatar
JohnnyC
JohnnyC is offline
Mick,
Great details!
Old 10-02-2012, 06:56 PM
piniongear's Avatar
piniongear
piniongear is offline
Simply put..... If you have a cast rear wheel then the problem is a too large tire.
If you have a spoke/nipple wheel instead, then it is pretty easy to fix the problem by moving the rim to the left a half inch.
pg
Old 10-03-2012, 12:22 PM
exemexer's Avatar
exemexer
exemexer is offline
Uh, yea, or you could do what IronMick said.
Old 10-10-2012, 04:58 PM
ChooChooCharlie
i fixed the generator Yay!! As for the tire, its spoked and looks like its all outta whack (like the rim is to far right) i also decided to check out the swingarm as well cause it looked kinda funny. the bolt will not come out ive tried pulling, pulling and turning, trying to catch it with a hammer do you guys have any ideas? and does this happen alot or is it an indicator of a messed up swingarm?
Old 10-10-2012, 05:46 PM
piniongear's Avatar
piniongear
The axle is most likely rusted inside the spacer, or inside the bearing races, or maybe even both.
All you can do is get yourself a can of Kroll penetrating oil and a very large plastic hammer.
Start by soaking the axle and every thing it goes through with the Kroll oil.
Give it over night to seep in and then apply another coat in the morning.
Take the hammer and start trying to beat the axle out of the frame.
Be sure to leave the nut ON THE AXLE to prevent ruining the threads.
If it moves at all, apply more Kroll and continue beating, or take a break and let the Kroll do it's thing.
Eventually you will get it out.
When you put it back in be sure to cover the axle with Silver Anti Seize material.
Regarding the rim........... It is as I said before, the wheel needs to be adjusted bringing the rim over to the left.
You can do this by loosening a spoke on the right and tightening the next spoke on the left.....all the way around the wheel.
Work in no more than half turns of the nipples.
Before you begin put a single drop of oil on each nipple where the spoke enters the nipple.
You also need a good fitting nipple wrench. Don't think you can use a small Cresent wrench because you will quickly ruin the nipples.
Most likely, for you, it will be best to take the wheel to a shop and let them do the adjustment.
pg
Old 10-11-2012, 06:41 PM
ChooChooCharlie
thanks! im going to take everything in and get it checked out now haha, its the best bet for sure does the bolt screw into the case? cause i cant find any nut in the manual
Quick Reply: 1980 sportster's chain rubs on tire no matter what
