speedo cable
The cable end is threaded. You have to disconnect the cable at the top then turn the entire cable as the fitting is crimped on at the wheel end.
Also there is a tiny tiny set screw into the bottom of the speedo drive preventing the cable from turning. Very difficult to see but it is there. Can be difficult to remove if it is in there tight - needs a tiny screwdriver.
