Ironhead A place to talk about Ironheads.
72 won't start now
Old 02-27-2013, 07:35 PM
PJRED70's Avatar
PJRED70
PJRED70 is offline
6th Gear
Default 72 won't start now
Well fixed the Nasty vacuum leak and finished my pushrod adjustment and disassembled and cleaned the carb(ss e) now I can't get it to run got spark its deff a fuel issue I poured a little gas in the hole and it started till that gas ran out but I smell fuel any ideas
Old 02-27-2013, 07:48 PM
IronMick's Avatar
IronMick
IronMick is offline
Electric start or kick start? Might have been better to continue from previous thread.
Old 02-27-2013, 08:03 PM
PJRED70's Avatar
PJRED70
PJRED70 is offline
6th Gear
Ya how do I close a thread and I'm sure you know this iron mick but I made a big mistake I have a ss carb and the two little ***** on the diaphragm well they both made it in but not the little spring the one for the diaphragm but not the one that goes with the ball think that's it?
Old 02-27-2013, 08:04 PM
PJRED70's Avatar
PJRED70
PJRED70 is offline
6th Gear
I explained that weird the little spring for the ball isn't in there but the big spring is
Old 02-27-2013, 08:48 PM
IronMick's Avatar
IronMick
IronMick is offline
I am not familiar with that carb. Best to correctly assemble it then test.
If there is important info in a previous thread you should be able to dig it up using the search that is on the blue commands line that has User CP on the left end. Search for threads started by yourself.
Old 02-27-2013, 09:03 PM
PJRED70's Avatar
PJRED70
PJRED70 is offline
6th Gear
Thanks for all the help
Old 02-28-2013, 07:00 AM
IronMick's Avatar
IronMick
IronMick is offline
There are a few different S&S carbs and i am not familiar with any of them. However, there might be some useful information here ...
super e rebuild..a slideshow
http://xlforum.net/vbportal/forums/s...d.php?t=676455
Instructions for S&S Super E & G Shorty Carbs - document #51-1012
http://www.sscycle.com/uploads/instr...stallation.pdf
Or post your questions in the other IronHead forum, here ...
Ironhead Sportster Motorcycle Talk (1957-1985)
http://xlforum.net/vbportal/forums/forumdisplay.php?f=7
Old 02-28-2013, 07:19 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
the small spring is for the acc pump so you do not have a part of the choke
if you cant find that spring i can help but it takes a week in the mail to you < the the one ball than spring than the other ball goes in next to it and with out it you may not be able to get it to stay running
Old 03-01-2013, 05:29 AM
PJRED70's Avatar
PJRED70
PJRED70 is offline
6th Gear
I actually found the spring on the ground were I rebuilt the car now if I can get Tim from workin on people's cars and work ill get her rollin
Old 03-01-2013, 05:30 AM
PJRED70's Avatar
PJRED70
PJRED70 is offline
6th Gear
I don't know how Tim got in there I don't even know a Tim haha
adamk
07-12-2017 06:47 PM
TheZombie
EVO
11
01-20-2015 09:43 AM
SportsterSnow
04-10-2013 04:05 PM
Beerninja
04-27-2009 09:31 AM
eidenmar
07-29-2008 10:44 AM
Quick Reply: 72 won't start now
